Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 10-08-2011, 10:24   #1 (permalink)
Member: 622934
Thanks Meter: 45
BlackBerry 9800 keypad Not Working...........
blackberry 9800 torch keypad not working.i also chang touch,middil strip,and keypad same problem.hlp.......
Old 10-13-2011, 23:06   #2 (permalink)
Member: 114381
Thanks Meter: 3
Did you find soloution i have same problem?
Old 10-14-2011, 00:26   #3 (permalink)
Member: 1113868
check the camera switch.........
Old 10-17-2011, 20:23   #4 (permalink)
ldp
Member: 1054948
try change sensor sliding
Old 10-17-2011, 20:36   #5 (permalink)
Member: 1618719
hope someone has a solution asap.
Old 10-17-2011, 21:31   #6 (permalink)
Tabrez1's Avatar
Member: 1343156
Thanks Meter: 45
Red face
I have blackberry 9800 torch same pro pleas help any one............
Old 05-06-2012, 18:18   #7 (permalink)
Member: 1228543
Sonork: james_29
try to change the crystal ic.near back up battery that's d driver ic 4 keypad in light keypad..
Old 05-07-2012, 13:25   #8 (permalink)
Member: 1720265
Thanks Meter: 2
i had the same problem, i managed to fix it yesterday, it happened to me after changing the digitizer, the problem was with the lcd cable that connect to the M/B, replaced that and its working great now.
Old 05-07-2012, 13:47   #9 (permalink)
Member: 1756583
Sonork: 85710
The keyboard on the Torch looks to be about the same size as the Bold 9700, but with a very different feel to it. Maybe it’s because the device is a slider, but it feels like the keys on the Torch are a little recessed, perhaps to allow a screen to roll over it.You must read your user manual or you can also ask person having this.
couch cleaning ny
Old 05-10-2012, 16:10   #10 (permalink)
Member: 236291
9800 keypad not woking
halo friends, Please change strip then reassemble phone perfectly, all will ok
Old 12-21-2012, 09:23   #11 (permalink)
Member: 505446
Thanks Meter: 44
Guys!i have the same problem!touch is original and working fine.but all keypads top ones and main quwetry keypad both not working.i have took out the mother board of faulty fone and put it in whole working fone's(slide,side camera buttons,top flex cable of LCD and the bottom key pad flex included).in other words every thing is changed,but still same problem.i believe it is related to key pad ics,can any one of you show me with a picture the location of keypad ics please?
BR,
A.Rehman
Old 05-18-2013, 16:57   #12 (permalink)
Member: 442126
Thanks Meter: 24
I had also same problem whn i change flat cable withot back body keypad not wrking..thn i assempled body full and screw prblm solved
The Following User Says Thank You to kmi2 For This Useful Post:
Old 06-16-2013, 15:33   #13 (permalink)
Member: 1031328
Thanks Meter: 22
dear friends bb 9800& 9810 key pad not working u will rimove the small crystal [5legs] same like simreader nokia its the side of charging connector
The Following User Says Thank You to hasbullahar For This Useful Post:
Old 07-24-2013, 23:43   #14 (permalink)
Member: 1977848
just change the touch original
Old 09-19-2013, 15:29   #15 (permalink)
Member: 424954
Put your ringer properly.......
becouse this work magnetic.....
key board activation
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 14:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 09:14
wintesla doesnt work ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:51
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 09:41
Page generated in 0.40635 seconds with 8 queries
