06-09-2013, 12:50 | #76 (permalink) | ||
No Life Poster Join Date: Jan 2011 Location: united arab emirates (uae)
Member: 1495471 Status: Offline Sonork: 1603910:abubablu Thanks Meter: 1,582 | Quote:
The Following User Says Thank You to bablu333 For This Useful Post: |
06-15-2013, 08:50 | #79 (permalink) | |
Freak Poster Join Date: May 2009 Location: kollam kerala live in riy
Member: 1031328 Status: Offline Thanks Meter: 25 | Quote:
06-15-2013, 08:56 | #80 (permalink) |
Member: 1031328 Status: Offline Thanks Meter: 25 | yap u can use the bb sak connect the device in bb sak read system then rimove codes [ not select eny codes] its automaticallyrimove then read event do u select clear event log its sure solve ur problem |
06-15-2013, 09:02 | #81 (permalink) |
Member: 1031328 Status: Offline Thanks Meter: 25 | no chance bos i am ripaired meny bb 9900 some time pa shorted some mobiles usb shorted aall its ok but no detecting usb its very dffclt prblm bb hanging . power off . network . reistart .usb not recognise i have its aall solution but no detecting usb its very dffclt |
06-20-2013, 09:36 | #86 (permalink) |
Member: 1495471 Status: Offline Sonork: 1603910:abubablu Thanks Meter: 1,582 | |
06-20-2013, 11:26 | #87 (permalink) |
Major Poster Join Date: Oct 2011 Location: south africa
Member: 1674958 Status: Offline Sonork: 100.1619424 Thanks Meter: 4 | sir i have a bb9900 when i putt charger without battery its nothing show red light or any thing else. but when i putt battery and charger than red light show. and after all phone come on completely. its show charging everything. and still on. and when i remove the charger than phone go off. i do new software. it done properly. but result is same the keypad is also stuck and phone is water damage any solution? |
06-20-2013, 12:56 | #88 (permalink) | |
Freak Poster Join Date: Jun 2012
Member: 1774307 Status: Offline Thanks Meter: 224 | Quote:
make it sure that your machine is clean up from water rehot or replace jet power .. U1303 ( open schematik) | |
The Following User Says Thank You to wawan tato For This Useful Post: |
06-22-2013, 11:08 | #89 (permalink) | |
06-22-2013, 12:20 | #90 (permalink) | |
Junior Member Join Date: Jun 2013
Member: 1962507 Status: Offline Thanks Meter: 0 | Quote:
Clean the Main Board by using IPA and also the Keyboard, Camera Socket, Housing etc so all component must be cleaner which has been affected by the Liquid. Use a different battery and try to switch on again, but I would avoid to pre-heat any part of the board till I am not sure if it is only a short circuit or any major component damaged by the liquid contamination. Main thing is clean every part of it and try again without apply any heat. The 9900 panel HEATSENSITIVE!!! under shields you still can have some liquid stacked but if you overheat any BGA components under shield... you will kill the Flash and Processor. Be careful with apply any heat... If you have to heat it the best is to remove every single shield with under-heater and airflow. That action will apply enough heat to the board which can re-solve the corrosion issues under shield.... BUT if the handset works with outer power supply I doubt if you have any PMU or PMIC issues with the phone.. It will be more likely battery, short circuit on Main Board or charging circuit issue. | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
