07-16-2014, 06:12 | #65 (permalink) |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | In your 9900 VREG_S3_1P8 volt is drain more current in any section. For that goto this post. http://forum.gsmhosting.com/vbb/f733...l#post10171004 |
08-09-2014, 20:04 | #67 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2237534 Status: Offline Sonork: kingkhan Thanks Meter: 0 | hi dears !! my prblm is 9900 dead(like fully no reaction) one a guy has a post am seened that to change the crystal osilator. k thaks but i have a bb 9860, is the crystal is same as 9900. pls replay am trouble...... |
08-17-2014, 02:24 | #69 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Neo-SANA
Member: 292106 Status: Offline Sonork: 100.1582885 Thanks Meter: 116 | Quote:
One final question i will want to ask to clear my imagination is, When you say "FULLSTOP"(dead end), Can't the POP Chip ( Cpu and Combo Chip) be replaced, I mean Remove epoxy glue and chips from other board to boards with faulty Cpu or Combo?. Will an Infra Station do a perfect refurbishing job in removing the epoxy glued Pop Chip in 9900?... | |
08-17-2014, 06:37 | #70 (permalink) | |
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
But before proceed you have good information of CPU and POP flash chip’s temperature. How much it’s bear. If you over temper than it’s becomes useless. Now guess how much temperature you need to remove hard epoxy glued of Pop flash than epoxy glued of CPU, CPU heat up twice here it’s dangerous for CPU. In CPU there are some sensitive I/O (in/out) gates. There are major chances to get fail those line or gates. When you use an Infra Station the melting point temperature of solder spread all over area where it’s attached include both CPU and POP flash IC. Blackberry use hard PCB material, so its need more temperature to released solder. If you have new fresh CPU and POP flash IC than you can do it. | |
08-20-2014, 06:17 | #71 (permalink) | |
http://forum.gsmhosting.com/vbb/f733...l#post10171004 Don't short 1.8v with any high volts. | |
10-08-2014, 06:15 | #75 (permalink) | |
If it's zero than first check shorting of those point.If ok than change MAIN POWER U-1201 ic. VSYS is internal vbat 3.6v if not getting than change JET POWER U1303. | |
