10-12-2014, 06:55 | #78 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
12-22-2014, 11:31 | #81 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2314735 Status: Offline Sonork: [email protected] Thanks Meter: 0 | Blackberry curve 8520 only red light not getting on |
12-28-2014, 11:24 | #83 (permalink) |
Member: 2318456 Status: Offline Thanks Meter: 0 | hello everyone, i was going through the internet then i came across this blog. i most confess you guys are doing great in here. i have a 9900 blackberry that is dead, no display, no red light. i have done every thing i know but it has refuse to respond. can any one in here please help me |
12-29-2014, 06:22 | #84 (permalink) | |
http://forum.gsmhosting.com/vbb/f733...l#post10247734 2.Does any thing not ok ? than post what's your problem. 3.Also change U1305 FuelGauge IC. GoodLuck | |
12-29-2014, 09:40 | #85 (permalink) |
No Life Poster Join Date: May 2013 Location: Cameroon Paris Age: 37
Member: 1943435 Status: Offline Sonork: 1955 Thanks Meter: 377 | |
05-16-2015, 15:31 | #86 (permalink) |
Junior Member Join Date: May 2015
Member: 2394854 Status: Offline Thanks Meter: 1 | bold 9900 red light blinking 10111 i have read every post in this thread and its really amazing the work you have done MUNIR!!!!!! i do not know what to replace or check or fix for error code 10111.... flash initialization problem. was it in a previous post and i missed it? |
The Following User Says Thank You to Alfalfa2Bum For This Useful Post: |
05-18-2015, 06:12 | #87 (permalink) | |
only 10111 red light blinke 9900 (or any bb modle) is impossible to recover bcoz flash chip fixed on proccessor. In some model flash chip is separate so any one can change it. | |
05-20-2015, 11:38 | #88 (permalink) | |
No Life Poster Join Date: Jun 2006 Location: Neo-SANA
Member: 292106 Status: Offline Sonork: 100.1582885 Thanks Meter: 116 | Quote:
05-22-2015, 06:05 | #89 (permalink) | |
1. flash chip itself damage. In this case by changing flash chip mobile will work ok. 2. cpu control lines to flash chip are fail than you have to change only cpu. When cpu gets fail but flash chip is ok. You can use same flash chip. In error code 10111 means flash initialization problem. It's doesn’t mean flash chip damage. Here two possibilities either flash chip or cpu damage. Easiest way first is to change flash chip. Cpu has so many ball and its little hard to reball or replace it. | |
The Following User Says Thank You to Munir For This Useful Post: |
