Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 10-08-2014, 19:02   #76 (permalink)
Member: 1351606
help please
i have one dead 9900 and one with 10111 but have the same readings on pmic please some suggestions
Old 10-08-2014, 19:10   #77 (permalink)
Member: 1351606
dead 9900
c1228 on my phone is 1.0v instead of 1.8 and c1233 is 1.10 is that ok please help
Old 10-12-2014, 06:55   #78 (permalink)
Member: 25662
Thanks Meter: 190
For 10111 its impossible due flash error flash chip stuck on CPU.look here http://forum.gsmhosting.com/vbb/f733...l#post10342968
Old 12-14-2014, 11:13   #79 (permalink)
Member: 721830
blackberry 9900 dead soluton
pleezzzz
Old 12-16-2014, 06:02   #80 (permalink)
Member: 25662
Thanks Meter: 190
pleezzzz
Now say Pleezz to you read this thread carefully and try to understand it and follow it.I had given complete method and imp point to check step by step.
The Following User Says Thank You to Munir For This Useful Post:
Old 12-22-2014, 11:31   #81 (permalink)
Member: 2314735
Blackberry curve 8520 only red light not getting on
Old 12-22-2014, 13:54   #82 (permalink)
Member: 25662
Thanks Meter: 190
pls... explain in detail of redlight?
its too long or sort, or with charger without battery how long?
its water damage?
Old 12-28-2014, 11:24   #83 (permalink)
Member: 2318456
hello everyone, i was going through the internet then i came across this blog. i most confess you guys are doing great in here. i have a 9900 blackberry that is dead, no display, no red light. i have done every thing i know but it has refuse to respond. can any one in here please help me
Old 12-29-2014, 06:22   #84 (permalink)
Member: 25662
Thanks Meter: 190
1.Go through my 40th and 48th posts http://forum.gsmhosting.com/vbb/f733...l#post10178821
http://forum.gsmhosting.com/vbb/f733...l#post10247734
2.Does any thing not ok ? than post what's your problem.
3.Also change U1305 FuelGauge IC.
GoodLuck
Old 12-29-2014, 09:40   #85 (permalink)
balengou1987's Avatar
Member: 1943435
Sonork: 1955
Thanks Meter: 377
pleezzzz
Hi bro
Repair Boot 9900
password: pshycoboy
Old 05-16-2015, 15:31   #86 (permalink)
Member: 2394854
Question bold 9900 red light blinking 10111
i have read every post in this thread and its really amazing the work you have done MUNIR!!!!!!
i do not know what to replace or check or fix for error code 10111.... flash initialization problem.
was it in a previous post and i missed it?
The Following User Says Thank You to Alfalfa2Bum For This Useful Post:
Old 05-18-2015, 06:12   #87 (permalink)
Member: 25662
Thanks Meter: 190
if your 9900's blinking error code is 10111 than its impossible. it will not connect to pc. Flash chip fault.only 3,5,7 codes recover by software. Whereas code no. 1. 80% hardware 20% software. 11,13,15 codes are recover by ram image file. Rest of codes is impossible.
only 10111 red light blinke 9900 (or any bb modle) is impossible to recover bcoz flash chip fixed on proccessor. In some model flash chip is separate so any one can change it.
Old 05-20-2015, 11:38   #88 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
When you say replace flash, do you mean replacing only the flash chip? so far i have replaced only flash chips in models that flash chip is separate from cpu (9220/30 ) after replacing only flash, phone is stucked on redlight loop, i had to replace cpu too, That is both cpu+flash must be replace for set to work okay... correct me if am wrong pls.
Old 05-22-2015, 06:05   #89 (permalink)
Member: 25662
Thanks Meter: 190
there are two possibility.
1. flash chip itself damage. In this case by changing flash chip mobile will work ok.
2. cpu control lines to flash chip are fail than you have to change only cpu. When cpu gets fail but flash chip is ok. You can use same flash chip.
In error code 10111 means flash initialization problem. It's doesn’t mean flash chip damage. Here two possibilities either flash chip or cpu damage.
Easiest way first is to change flash chip. Cpu has so many ball and its little hard to reball or replace it.
Old 05-26-2015, 08:33   #90 (permalink)
Member: 1567453
black berry Q10 charging solution pls
The Following User Says Thank You to hessentee For This Useful Post:
Page generated in 0.28773 seconds with 10 queries
