04-15-2014, 07:53 | #46 (permalink) |
Junior Member Join Date: Oct 2008 Location: palghat
Member: 878460 Status: Offline Sonork: [email protected] Thanks Meter: 0 | |
04-18-2014, 06:12 | #48 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
Change Cpu crystal(Oscillator) X1101. the last chance. No any more step or way. I hope your phone will be "get well soon". Sorry for bad english. | |
05-29-2014, 21:46 | #51 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2077936 Status: Offline Thanks Meter: 21 | While it works with 9900's that don't power on but show the red light it doesn't seem to resolve the 9900's with the 3 fast blinking lights. Do you have a solution for this Munir? |
05-30-2014, 15:30 | #54 (permalink) |
Member: 2077936 Status: Offline Thanks Meter: 21 | near power ic. I've fixed 3 devices so far. All devices would flash a solid red for a few seconds, go away and then come back. The devices that I am still unable to think are the flashing red lights (3 or 4 blinks). I have tried replacing the oscillator by the power ic on these devices and same symptoms. Do you suggest replacing the oscillator by the CPU or is it more likely the power ic or smaller ics under the emi heat sheilds to the left that sometimes need to be replaced. |
The Following User Says Thank You to loomingx For This Useful Post: |
05-31-2014, 05:59 | #55 (permalink) | |
2.In your solid red for a few seconds case insert charger without battery & wait after red light it's show no battery symbol in display than 1. change touchscreen, It's most important at booting time that if mobile can't sense touchscreen than it will reboot again frequently.2.check two line most important I2C_SCL_AUX & I2C_SDA_AUX. It's used in many section for that reffer schematic and replace those thing and put it again If you will not put it again than it's gives new problem like hang or reboot after sometime. | |
06-01-2014, 20:15 | #56 (permalink) |
Member: 2077936 Status: Offline Thanks Meter: 21 | The ones that I was able to fix showed a solid red for a few seconds, went away for 5-10 seconds and then come back in a constant loop. replacing the crystal oscillator solved this issue. The devices that I have and can not fix flash the red light 3 or 4 times quickly. I have already tried replacing the touchscreen, complete screen assembly, reloading the software through BB Desktop Manager, App loader, and other 3rd party programs. If it is not a part, the software, or the crystal oscillator what is the most likely component that needs to be replaced? I'm sorry but I don't know what you mean by: I2C_SCL_AUX & I2C_SDA_AUX |
06-02-2014, 06:53 | #57 (permalink) | |
The Following User Says Thank You to Munir For This Useful Post: |
07-09-2014, 06:01 | #60 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2079111 Status: Offline Thanks Meter: 0 | please any body with the solution for 9900 and 9930 always restart unless i plug charger before i can used the phone, immediately i removed charger phone shut down instant. any solution to it please. |
