Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 02-03-2014, 09:05   #31 (permalink)
Member: 25662
Thanks Meter: 190
Hello all bro confused for 9900 fully dead.
Igot 95% success in fully dead 9900 and i had show all imp point in this thread [COLOR="red"]http://forum.gsmhosting.com/vbb/f733...ution-1693063/[/COLOR also in my post http://forum.gsmhosting.com/vbb/f733...3/#post9966413 pls. try to understand method and reply in that thread.only 10111 red light blinke 9900 is impossible to recover bcoz flash chip fixed on proccessor.
I THANX d-Artigo the gentlemen how has helpful info & picture.and also THANX bro naqvi66
GOODLUCK, try best & work hard.
where there's a will there's a way
Old 03-04-2015, 08:46   #32 (permalink)
Member: 2279922
Sonork: 100.1662328
Thanks Meter: 2
Respected,
I have bb 9900. The problem is LCD light dim after 30 second. If charging jack insert continuously LCD not dim. Plz help me.
Old 03-04-2015, 12:57   #33 (permalink)
Member: 619957
Thanks Meter: 50
101% tested by me not detected by pc if flash ic is damaged
Originally Posted by khanmrd View Post
tell then no solution plz help a have also many sates plz some one help brother
it's a same NAND or you can call Emmc problem ...I will try to change flash drive with working phone lets see if its works
Old 03-04-2015, 13:58   #34 (permalink)
Member: 25662
Thanks Meter: 190
Originally Posted by a1mobile882288 View Post
Respected,
when you insert charging jack with or without battery?
If without battery than goto this post http://forum.gsmhosting.com/vbb/f733...ppear-1908733/
if with battery LCD remain on than visit here http://forum.gsmhosting.com/vbb/f733...creen-1898739/
Old 03-06-2015, 22:05   #35 (permalink)
Member: 2358037
Some should help us on dis 9900 problem of a tin
Old 03-23-2015, 20:36   #36 (permalink)
Member: 2323636
Sonork: arditgsm
only replace no rehot because is the same thing
Old 03-26-2015, 06:46   #37 (permalink)
Member: 2045598
i need help on dis issue too
Old 04-03-2015, 09:56   #38 (permalink)
Member: 25662
Thanks Meter: 190
goto my 31st post http://forum.gsmhosting.com/vbb/f733...l#post10067284
Old 04-03-2015, 19:28   #39 (permalink)
Member: 2363574
Thanks'...................................
Page generated in 0.18969 seconds with 9 queries
