Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 07-09-2014, 09:00   #1 (permalink)
sumon_tele's Avatar
Member: 1960103
Sonork: 100.1651089
Thanks Meter: 49
BlackBerry 9900 onle read lihgt no power ane solution...
help me................
Old 08-15-2014, 14:07   #2 (permalink)
Member: 1940376
Sonork: since 1928
Thanks Meter: 11
10111 or 101111 ..........
Old 08-15-2014, 14:11   #3 (permalink)
ch wajid's Avatar
Member: 2203737
Sonork: 1656500
Thanks Meter: 462
blinking red light solution for all blackberry
new and tried on 100s off bb modules success on all
1. download blackberry master control program and install it
2. download CFP_3.9.0.175.exe keep on desktop
3. open master control program and click on setting wheel on left hand side and
in enable protected control type BrickBerry same as it is here
4. right click on alien face cfp button at left hand side.
5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop.
6. connect your bb without battery on top command-line interface (CLI)
select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job.
let the bb master control be open..........
now the trick is to load os
1. In bb master control on right hand side below right click on apploader
it will loader/nojvm connect your phone follow the instruction thats it you have done the job..
please write me if you have any doubt or error
thanks
Wajid
if gives you error again go to step 6 select nuke and then wipe after this if says error dont cancel the procedure just disconnect the phone remove the battery re insert and wait untill the phone finish then connect the phone and press retry
The Following User Says Thank You to ch wajid For This Useful Post:
Old 08-16-2014, 14:48   #4 (permalink)
Member: 950002
Sonork: Laa Elaha Ellallah
Thanks Meter: 119
load full os...by loader
Old 05-04-2015, 23:40   #5 (permalink)
Member: 2381233
Sonork: 100.28977
Please my phone device is having the same fault , I need hardware solution to it .
Old 05-05-2015, 09:58   #6 (permalink)
Member: 491745
Thanks Meter: 6
bro write only fast boot flash file then tell me
Page generated in 0.16623 seconds with 8 queries
