08-15-2014, 14:11 | #3 (permalink) |
Freak Poster Join Date: Jun 2014 Location: United States Of Islam
Member: 2203737 Status: Offline Sonork: 1656500 Thanks Meter: 462 | blinking red light solution for all blackberry new and tried on 100s off bb modules success on all 1. download blackberry master control program and install it 2. download CFP_3.9.0.175.exe keep on desktop 3. open master control program and click on setting wheel on left hand side and in enable protected control type BrickBerry same as it is here 4. right click on alien face cfp button at left hand side. 5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop. 6. connect your bb without battery on top command-line interface (CLI) select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job. let the bb master control be open.......... now the trick is to load os 1. In bb master control on right hand side below right click on apploader it will loader/nojvm connect your phone follow the instruction thats it you have done the job.. please write me if you have any doubt or error thanks Wajid if gives you error again go to step 6 select nuke and then wipe after this if says error dont cancel the procedure just disconnect the phone remove the battery re insert and wait untill the phone finish then connect the phone and press retry |
The Following User Says Thank You to ch wajid For This Useful Post: |
