Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 11-20-2011, 10:25   #1 (permalink)
Member: 1682761
Thanks Meter: 24
BlackBerry 9900 red light - 100% work solution
1. Download firmware 9900 OS 7.0.0.540 Free File Hosting, Online Storage &amp File Upload with FileServe
1.1. Full charge the blackberry
2. Start Loader.exe
3. Connect BlackBerry 9900 no battery
4. "Connecting to JVM" - Insert the battery.
Work 100%, I repaired the 8 pieces...
The Following 22 Users Say Thank You to Pavel K For This Useful Post:
Old 11-25-2011, 03:52   #2 (permalink)
Member: 534777
Thanks Meter: 213
2. Start Loader.exe
Hi, have tried your solution and updates the phones firmware but i always get this error at the end of the loading operation:
"A fatal error has occurred while updating your device's software. Please try again.
Mdodule incompatible. [J:0x00000011]
The update file "net_rim_crypto.cod" for application"Blackberry Crypto Library" is not compatible with the version of the application that is intalled on your device. Delete the application from your device, and then re-install the application. Warning: If you delete an application from your device, you also delete any device data that is associated with the application."
my question is when i connect via crackutilities or BBSAK, i'm able to see the "net_rim_crypto.cod" file but there are several files like this such as
"net_rim_crypto_1
"net_rim_crypto_2
"net_rim_crypto_3
"net_rim_crypto_resource_ar"
"net_rim_crypto_resource_de"
(a few more with language variations)
"net_rim_crypto_resource_lib"
which of the "net_rim_crypto" files should i delete and what are the dangers of deleting such a file??
how do i install it to my device after deletion???
please i need your kind assistance in this matter.
thanx and best wishes
NB: when i leave the phone on, it loads with the "BLACKBERRY" logo and after sometime of having the bar loading to the end, i have
"App Error 200. Reset" appearing on my screen.
The Following User Says Thank You to wodashie For This Useful Post:
Old 11-25-2011, 04:49   #3 (permalink)
Member: 607782
Thanks Meter: 10
"net_rim_crypto_1
"net_rim_crypto_2
"net_rim_crypto_3
many time i got this situation.. before i change my windows from sp2 to sp3... and now im using sp3 .. since now i never find "crypto" problem again
The Following User Says Thank You to brandon_ina For This Useful Post:
Old 11-25-2011, 05:09   #4 (permalink)
Member: 534777
Thanks Meter: 213
i have 3 pc, one with xp sp2, one with xp sp3 and the other one with win7. have tried on the xp's and i keep getting this crypto error message.
the win7 doesn't even load loaer application for me to try and dm cant even connect to bootrom (always give error).
anyone with some experirence or suggestion for me to fix this problem???
how do i delete the said crypto file and how will it affect my phone in reloading the os.
thanx
Old 11-25-2011, 05:28   #5 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 321
Latest Blackberry Desktop needs SP3 to install ...
Old 11-25-2011, 06:01   #6 (permalink)
Member: 534777
Thanks Meter: 213
thanx. i have done that on my sp3 xp and win 7 and not success yet. my interest is with the file deletion and reloading. how do i go about it assuming that can fix this issue with my phone.
thanx for your help.
Old 11-25-2011, 06:32   #7 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 497
Originally Posted by DUAL_GEAR View Post
Thanks Bro for your procedure....
this is not he, s produce. this is original b.b os update release.
use ur brain and use search.
Old 11-25-2011, 06:57   #8 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 405
@all ...
a little info to add... for new OS 7 update xp with SP3 required ... or better use windows7...
.:KHALIFA:.
Old 11-25-2011, 09:48   #9 (permalink)
Member: 534777
Thanks Meter: 213
Originally Posted by .:KHALIFA:. View Post
@all ...
.:KHALIFA:.
loader.exe does not work on my win7 but works ok on xp sp3 only i get the errors i posted above. how do i fix this error???
Old 12-09-2011, 20:48   #10 (permalink)
Member: 1703288
I am doing the exact same thing... But when it says "reconnecting to JVM" y plug the battery in and then I get the following error:
Aplication loader was unable to connect to your device. Please re-connect your device, enter the password, if required, and click Retry
What should I do??
Old 12-10-2011, 10:16   #11 (permalink)
Member: 1468680
Sonork: no
Thanks Meter: 9
2. Start Loader.exe
Report Post
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 12-10-2011, 21:00   #12 (permalink)
Member: 17362
Thanks Meter: 242
NOt all can be fixed like this.. Many have SHorts on boards cause idiots at blackberry plant did not inspect re flow machines placing chips.. Bad shorts.. Best viewed on Xray bga inspection machine.. Stupid plant workers in Mexico.. They knew this and still sold over 30,000 pcs to many peoples!! NO WARRANTY ON NO SUTEL XXXXX-XXXXX no probation numbers...
You can say Blackberry sold many [email protected] up phones with defects on purpose!! sold to many distributors.... Sold As Is..
SUTEL XXXX-XXXX on your phone..... Buy 50pcs you will get back 15pcs dead...
The Following User Says Thank You to gsm1999 For This Useful Post:
Old 12-16-2011, 19:20   #13 (permalink)
Member: 924746
Thanks Meter: 7
the solution is working but now when i insert a sim card and when its start searching for network it reboots... :S any idea?
Old 12-23-2011, 19:51   #14 (permalink)
Member: 58048
BB9900 Dead
Hi, my BB 9900 is completely dead. I mean no red light no nothing. I tried to reload OS but pc won't recognize it despite whatever I do.
Any solution please ?
Thankx
Old 12-26-2011, 20:22   #15 (permalink)
Member: 1656305
Sonork: 100.1624503
Thanks Meter: 46
Hi, Do I need Desktop Manager 7 for doing this?.... i've tried several times with no luck... please, help... i'm a 9900 owner
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
wintesla doesnt work ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 15:51
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 09:41
Page generated in 0.48372 seconds with 9 queries
