03-30-2013, 10:22 | #4 (permalink) | |
Freak Poster Join Date: Sep 2009 Location: Pringgondani
Member: 1121495 Status: Offline Thanks Meter: 28 | Quote:
because there is no tool of the scheme to address the issue properly. thanks | |
04-02-2015, 10:02 | #9 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1616118 Status: Offline Sonork: sam ahmed Thanks Meter: 1 | 2/1/11 Hi I've searched all over for the answer to this problem, and nothing. Hopefully someone can help. I have a blackberry curve 9300 thats about 1 months old. Two days ago the trackpad started to work only with ALT or SHIFT keys. Problem is: Situation 1) In the home menu the track pad scrolls great. It can move up to change ring settings, left, right, down, etc. Completely normal. Situation 2) I press the menu key and the trackpad no longer works. I can't scroll left right up or down through the icons. Now when I try holding the alt key OR the shift key, the track pad works again... Only in some menus do I need to hold the alt or shift key to activate the track pad (and I need to hold the shift or alt key for the track pad to work, ie, if I release the alt/shift key it no longer responds) Situation 3) When sending a text message when I use the track pad to scroll down and send a message, it takes the last character and cycles through the symbols for that character2/1/11 Hi I've searched all over for the answer to this problem, and nothing. Hopefully someone can help. I have a blackberry curve 9300 thats about 1 months old. Two days ago the trackpad started to work only with ALT or SHIFT keys. Problem is: Situation 1) In the home menu the track pad scrolls great. It can move up to change ring settings, left, right, down, etc. Completely normal. Situation 2) I press the menu key and the trackpad no longer works. I can't scroll left right up or down through the icons. Now when I try holding the alt key OR the shift key, the track pad works again... Only in some menus do I need to hold the alt or shift key to activate the track pad (and I need to hold the shift or alt key for the track pad to work, ie, if I release the alt/shift key it no longer responds) Situation 3) When sending a text message when I use the track pad to scroll down and send a message, it takes the last character and cycles through the symbols for that character2/1/11 Hi I've searched all over for the answer to this problem, and nothing. Hopefully someone can help. I have a blackberry curve 9300 thats about 1 months old. Two days ago the trackpad started to work only with ALT or SHIFT keys. Problem is: Situation 1) In the home menu the track pad scrolls great. It can move up to change ring settings, left, right, down, etc. Completely normal. Situation 2) I press the menu key and the trackpad no longer works. I can't scroll left right up or down through the icons. Now when I try holding the alt key OR the shift key, the track pad works again... Only in some menus do I need to hold the alt or shift key to activate the track pad (and I need to hold the shift or alt key for the track pad to work, ie, if I release the alt/shift key it no longer responds) Situation 3) When sending a text message when I use the track pad to scroll down and send a message, it takes the last character and cycles through the symbols for that character |
04-03-2015, 05:57 | #10 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
