blackberry curve 9220 trackpad problem blackberry curve 9220 trackpad problem plz.. give me solution... |
plz give me solution.................... plz give me solution.................... |
Eso es problema de humedad, calienta los dos integrados que van debajo y sale 100% |
because there is no tool of the scheme to address the issue properly. thanks |
Pls U take out D1812 the problem is solve, that Deode is shorting. |
clean toe Control Keypad IC |
please send the picture of diode |
2/1/11 Hi I've searched all over for the answer to this problem, and nothing. Hopefully someone can help. I have a blackberry curve 9300 thats about 1 months old. Two days ago the trackpad started to work only with ALT or SHIFT keys. Problem is: Situation 1) In the home menu the track pad scrolls great. It can move up to change ring settings, left, right, down, etc. Completely normal. Situation 2) I press the menu key and the trackpad no longer works. I can't scroll left right up or down through the icons. Now when I try holding the alt key OR the shift key, the track pad works again... Only in some menus do I need to hold the alt or shift key to activate the track pad (and I need to hold the shift or alt key for the track pad to work, ie, if I release the alt/shift key it no longer responds) Situation 3) When sending a text message when I use the track pad to scroll down and send a message, it takes the last character and cycles through the symbols for that character2/1/11 Hi I've searched all over for the answer to this problem, and nothing. Hopefully someone can help. I have a blackberry curve 9300 thats about 1 months old. Two days ago the trackpad started to work only with ALT or SHIFT keys. Problem is: Situation 1) In the home menu the track pad scrolls great. It can move up to change ring settings, left, right, down, etc. Completely normal. Situation 2) I press the menu key and the trackpad no longer works. I can't scroll left right up or down through the icons. Now when I try holding the alt key OR the shift key, the track pad works again... Only in some menus do I need to hold the alt or shift key to activate the track pad (and I need to hold the shift or alt key for the track pad to work, ie, if I release the alt/shift key it no longer responds) Situation 3) When sending a text message when I use the track pad to scroll down and send a message, it takes the last character and cycles through the symbols for that character2/1/11 Hi I've searched all over for the answer to this problem, and nothing. Hopefully someone can help. I have a blackberry curve 9300 thats about 1 months old. Two days ago the trackpad started to work only with ALT or SHIFT keys. Problem is: Situation 1) In the home menu the track pad scrolls great. It can move up to change ring settings, left, right, down, etc. Completely normal. Situation 2) I press the menu key and the trackpad no longer works. I can't scroll left right up or down through the icons. Now when I try holding the alt key OR the shift key, the track pad works again... Only in some menus do I need to hold the alt or shift key to activate the track pad (and I need to hold the shift or alt key for the track pad to work, ie, if I release the alt/shift key it no longer responds) Situation 3) When sending a text message when I use the track pad to scroll down and send a message, it takes the last character and cycles through the symbols for that character |
