blackberry curve 9300 trackpad connector .! i broke the trackpad flex connector for my blackbery curve 9300 i am not able to connect any trackpad flex all prints are perfect on the board how can i obtain a same new jack ..? please help my ..!!:confused::rolleyes::o |
Hi, I'm not sure if you can buy a new trackpad flex connector. If you can't buy a new one then you can try desoldering one from another broken 9300. I have used a desoldered one before & it worked well. Regards, Nazty. |
9300 Kepler TrackPad |
this is troubel shooting for trackpad or mmc?? |
sir actually im unable to find any dead board or any similar connector is there any possiblity that i can find a similar jack from any other board |
9300 Kepler TrackPad Quote:
sir i have done this kepler part according to me the joystick willl now work fine but there is a problem now my phone is restarting on its own . the first redlight apears and the pn keeps on restarting . if tried flashing but the phone is restarting so waste of time it doesnt take flash on it |
location of blackberry harddrive where is the hard drive of a blackberry located |
sir i tried d=removing it n the phn works fyn after romving it but when i solder it again it starts giving me the error i have checked its nt shorting anywher. |
take connector from blackberry 9800 ribbon easily removed |
connect youur trackpad again the same as it was restarting and try by removing one connection, again unto another, till you found the connection that has got problem,, when you found it, let all member know again,, |
