Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 10-08-2012, 22:55   #1 (permalink)
Member: 1822231
blackberry curve 9300 trackpad connector .!
i broke the trackpad flex connector for my blackbery curve 9300 i am not able to connect any trackpad flex all prints are perfect on the board how can i obtain a same new jack ..? please help my ..!!
Old 10-08-2012, 23:03   #2 (permalink)
NAZTY's Avatar
Member: 553264
Thanks Meter: 594
Hi,
I'm not sure if you can buy a new trackpad flex connector. If you can't buy a new one then you can try desoldering one from another broken 9300. I have used a desoldered one before & it worked well.
Regards,
Nazty.
Old 10-09-2012, 22:28   #3 (permalink)
Member: 958720
Thanks Meter: 58
Thumbs up 9300 Kepler TrackPad
The Following User Says Thank You to exus For This Useful Post:
Old 10-11-2012, 08:16   #4 (permalink)
Registered User
Member: 1819544
Sonork: nandacell
this is troubel shooting for trackpad or mmc??
Old 10-11-2012, 18:50   #5 (permalink)
Member: 1822231
sir actually im unable to find any dead board or any similar connector is there any possiblity that i can find a similar jack from any other board
Old 10-12-2012, 15:46   #6 (permalink)
Member: 958720
Thanks Meter: 58
TrackPad 9300 Kepler...!!
Could use 9100, 9320, 9300 Board...!!
Old 12-23-2012, 16:49   #7 (permalink)
Member: 1822231
sir i have done this kepler part according to me the joystick willl now work fine but there is a problem now my phone is restarting on its own . the first redlight apears and the pn keeps on restarting . if tried flashing but the phone is restarting so waste of time it doesnt take flash on it
Old 12-23-2012, 18:20   #8 (permalink)
Member: 958720
Thanks Meter: 58
Try removing the trackPad... Maybe itīs shorted...
Old 12-23-2012, 23:26   #9 (permalink)
Member: 114673
location of blackberry harddrive
where is the hard drive of a blackberry located
Old 12-24-2012, 10:52   #10 (permalink)
Member: 1822231
sir i tried d=removing it n the phn works fyn after romving it but when i solder it again it starts giving me the error i have checked its nt shorting anywher.
Old 01-08-2013, 08:31   #11 (permalink)
Member: 1713670
Thanks Meter: 7
take connector from blackberry 9800 ribbon easily removed
Old 01-18-2013, 22:51   #12 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
9300 trackpad solution 100%
Old 01-23-2013, 20:37   #13 (permalink)
Member: 1717317
Sonork: zxcvb123
Thanks Meter: 16
connect youur trackpad again the same as it was restarting and try by removing one connection, again unto another, till you found the connection that has got problem,, when you found it, let all member know again,,
Page generated in 0.31650 seconds with 7 queries
