blackberry hardware solution Let make a thread for blackberry hardware solution, post and request anything about blackberry hardware here? |
blackberry battery drained.shutting down handheld i have 2 blackberry who say that error blackberry battery drained.shutting down handheld i have change the battery but i still get the sAME PROBLEM |
salam i have to balckberry when i put battery inside it shows a waiting sign and restart i tried to make it software but multistage error on software.. can any ony tell me is this hardware or software. |
I've the same problem. I think It's not a software issue. May be TPS65820 (Power Management) 8820 BB indentifies the wrong signal from the port in battery. Does any one have idea, or a sugguest for resolving. Thanks. |
can u give me Blackberry 8310 USB ways + charging ways COZ PC dont sound like usb conected when i insert USB cable only Red light Steady for few sec then blinking |
hi all i alsoo had the same problem with the bold 9000. i open the set and remove the both stickers imei and key pad.. alsoo remove the camera and scrol boll and dip in the thinner for 2 hours.and after i just dry it with hot air and write loaders from C/:MML/HHFILE/LOADERS/9000.bat..(if u already instaled MFI multiloaders) without betrey.. after i make it full flash. its working now thax |
i think this maybe help you.. http://forum.gsmhosting.com/vbb/showthread.php?t=560789 |
my phone black berry 8100 network low or not good net work what can did to repair it |
blackberry bold or 9000 buzzer solution 10000% working http://i253.photobucket.com/albums/h...7/bb900buz.jpg pls click thanks botton:p:):) |
any one can share blackberry 8100 battery cross sign on screen soul? re flashed phone, changed many batteries from working phones, but same, any hardware help? |
HI, I have a BB 8320 that can't turn on, I flash it but said that the apploader can reconect the BB... again. the the battery is full. I think it is hardware problem. like can't conect the battery. somebody know about that?? thanks |
blackberry 8310 charging ways |
HI, I have a blackberry 8100 that say call failed, I did repair imei, pin, change IT policy. but keep given the call failed error. I think that would be hardware problem. somebody know about that? and how I can repair it??? thanks |
