Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 01-26-2012, 20:30   #256 (permalink)
Member: 17362
Thanks Meter: 242
No real solution, just bs from many
The Following User Says Thank You to gsm1999 For This Useful Post:
Old 01-28-2012, 18:21   #257 (permalink)
Member: 1548507
Sonork: 100.1603342
Thanks Meter: 2
Bb tour 9630 no charging
Hi sir , i have a 9630 tour , i replaced its charging jack , but still there is no charging , even it will not indicate any type of charging , help me pls , ,, there is any ic that i changed to help in charging
The Following User Says Thank You to gsmhitter For This Useful Post:
Old 01-28-2012, 20:07   #258 (permalink)
Member: 1387216
Thanks Meter: 5
I have a similar problem with an 8900, when the charger is connected the clock appears which shows the phone is receiving power but the battery does not charge (battery is good) can you suggest anything please.
BK
Old 01-29-2012, 07:35   #259 (permalink)
Member: 742362
Thanks Meter: 2
Tx you buangeeet ya Om.....
Old 01-29-2012, 11:32   #260 (permalink)
Crazy Poster
Member: 325085
Thanks Meter: 11
really thnx bro and more solution?
Old 01-31-2012, 15:47   #261 (permalink)
Member: 777756
Thanks Meter: 44
bb9105 insert sim
hi, need bb9105 insert sim solution.
Old 02-09-2012, 01:48   #262 (permalink)
Member: 601591
Thanks Meter: 84
thanks v much keep on moving........
Old 02-10-2012, 08:48   #263 (permalink)
ichal_spy's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 5,479
The Following 2 Users Say Thank You to ichal_spy For This Useful Post:
Old 02-10-2012, 09:40   #264 (permalink)
Member: 866574
Sonork: dare
Hi,I have bb bold 9780,only flash light comes on,no power;what can I do?
Old 02-10-2012, 10:07   #265 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
9630 and 9530 charging ways,
Old 02-10-2012, 10:31   #266 (permalink)
Member: 371952
Mr.spy can help me 9630 signal connection auto off,any solution for this?
Already upgrade still same problem.
Old 02-10-2012, 15:50   #267 (permalink)
Member: 17362
Thanks Meter: 242
Blackberry 9900 Fuse info
Second bottom fuse when is burnt will
cause " X" when battery is connected.
Battery is good and will display X on screen - Change Fuse...
1st fuse is for CPU Power
The Following 2 Users Say Thank You to gsm1999 For This Useful Post:
Old 02-13-2012, 03:09   #268 (permalink)
Member: 1207334
Hello i have blackberry 9700 that show cross or X on battery
I already replace battery and clean battery connectors, but still same problem.
I figure its hardware problem plz post picture on how to fix
Thanks
Old 02-15-2012, 02:54   #269 (permalink)
Member: 535199
Thanks Meter: 4
hello i have blackberry 9700 when i put the battery the flash light of camera always on when i check the unit with tester it has short a little can u give me which part i will remove or replace?
The Following User Says Thank You to wanclickid For This Useful Post:
Old 02-15-2012, 18:18   #270 (permalink)
Member: 1034912
bb 8520 white lcd-need help
Originally Posted by karaarslan View Post
Hi ALL
Can anybody help me whit the problem blackberry 8520 and 9700 white lcd. also after renew the lcd with same lcd nummer
I have change by every 3 new lcd whit same number but its same
I have blanc lcd by every new one lcd if change it
hello dear, me also have the same problem, can anybody help?
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 11:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 04:52
Pic Solution jan Nokia Hardware & Hardware Repair 8 10-11-2010 10:56
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.44716 seconds with 9 queries
