Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 03-27-2015, 05:13   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
blackberry playbook camera problem
this ic is damaged from corner
any member know wat is the working of this ic ?
Old 03-29-2015, 16:11   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Sometimes camera work ,sometimes white and grey stripes,sometimes show close any other instances of the camera and try again
Old 03-31-2015, 23:39   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i remove this crystal ic and when i try to replace i forgot the direction bcoz there is no notch on ic
by searching on google i got the direction but problem is no notch on ic, any idea to jumper this crystal ic and wat is the working of this ic ?
Old 04-01-2015, 06:18   #4 (permalink)
Member: 25662
Thanks Meter: 190
not possible to jumpper, I mean ist camera related volt like 2.8v and 1.8v.
To decide notch on ic measure ic by multimeter in diode function red probe to ground black probe for measuring.
1. how many ground use on pcb? On base of ground to ground may you get very lowest reading or direct link, two outside capacitor's point in ic you get low reading also vbat point has low reading. By this way you decide notch of ic.
Old 04-01-2015, 13:34   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Only one ground in this ic
Old 04-01-2015, 23:49   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
already change ic but still same white and grey lines but when click on capture , the picture is saved in pictures (images only white and grey lines)
Old 04-02-2015, 03:48   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Where are experts of blackberry section ?
Old 04-03-2015, 20:39   #8 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
Reball or change this 5 MP imaging processor XTV0987
The Following User Says Thank You to cal_guy For This Useful Post:
Old 04-03-2015, 20:45   #9 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
Pin 1
Old 04-03-2015, 23:29   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
already rehot 5mp ic but same
Old 04-03-2015, 23:49   #11 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
Change it ..
Old 04-04-2015, 01:21   #12 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
any other model which have this ic bcoz dont have same pcb
Old 04-04-2015, 06:32   #13 (permalink)
Member: 25662
Thanks Meter: 190
you can get it from Blackberry Torch (9800)
The Following 2 Users Say Thank You to Munir For This Useful Post:
Page generated in 0.19954 seconds with 8 queries
