Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 03-16-2017, 14:53   #1 (permalink)
Member: 2641406
Thanks Meter: 84
BlackBerry Q10 not reading sim card - sim slot replacement tutorial
In this video you will find out how to replace SIM slot on the mainboard in your BLACKBERRY Q10:
http://www.youtube.com/watch?v=k33m0X92VBY
The Following User Says Thank You to Baladeva For This Useful Post:
Old 05-17-2017, 11:14   #2 (permalink)
Member: 2630469
Thanks Meter: 8
I've made quite many such a repairs, in my opinion you should increase temperature to make it more easy, above that good quality video bro!
Old 05-23-2017, 08:52   #3 (permalink)
Member: 2641406
Thanks Meter: 84
If you increase temperature you'll cause irreversible damage to the mother board, so I think it is not a good idea.
Old 05-25-2017, 11:00   #4 (permalink)
Member: 2634426
Thanks Meter: 15
Can I make it with only hot air gun, is it safe to provide such repair with such an equipment?
Old 05-27-2017, 08:42   #5 (permalink)
Member: 2669015
Sonork: jude101
Thanks Meter: 7
please i need the blackberry leap sim ways anybody wit the solution
Old 06-05-2017, 06:58   #6 (permalink)
Member: 2641406
Thanks Meter: 84
muhamalak you need professional tools, there is no other way, using hot air you will destroy the mother board!
Old 06-14-2017, 15:52   #7 (permalink)
Member: 1518920
Thanks Meter: 16
I have replace the sim slot but now I get no signal network, what can I do?
Old 06-19-2017, 06:54   #8 (permalink)
Member: 2641406
Thanks Meter: 84
It is probably due to the mainboard defect, I solve many network problems by replacing IC, here is the exemplary video:
http://www.youtube.com/watch?v=Uf-K_dvMPEA
Old 07-01-2017, 10:16   #9 (permalink)
Member: 1518920
Thanks Meter: 16
What kind of flux should I use?
Old 08-19-2017, 07:49   #10 (permalink)
Member: 2634426
Thanks Meter: 15
I reccomend HF Rework Jelly Flux, very good flux for soldering on mainboard
Old 08-24-2017, 09:18   #11 (permalink)
Member: 2724771
Thanks Meter: 12
I need to stick the chip cover to tha mainboard, what adhesive do you reccomend?
Old 09-15-2017, 07:05   #12 (permalink)
Member: 2748073
Thanks Meter: 8
I also have trouble with adhesives they are mostly to weak to keep the back cover to the frame. Almost all back covers are coming off, need some solution!
Old 09-20-2017, 19:52   #13 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
You can sratch the ground portion near the part of the cover you want to hold in place and then apply solder to connect the part to the board for strong support.
Old 09-29-2017, 06:31   #14 (permalink)
Member: 2634426
Thanks Meter: 15
I agree. The back cover wont hold if you don't clean the frame properly, use the proper liquid.
Old 10-05-2017, 06:31   #15 (permalink)
Crazy Poster
Member: 2757196
Thanks Meter: 3
I need to do some soldering stuff and need leaping ways, anyone could share the scheme for it, thanks in advance.
Page generated in 0.18963 seconds with 8 queries
