BlackBerry Q10 not reading sim card - sim slot replacement tutorial In this video you will find out how to replace SIM slot on the mainboard in your BLACKBERRY Q10: |
I've made quite many such a repairs, in my opinion you should increase temperature to make it more easy, above that good quality video bro! |
If you increase temperature you'll cause irreversible damage to the mother board, so I think it is not a good idea. |
Can I make it with only hot air gun, is it safe to provide such repair with such an equipment? |
please i need the blackberry leap sim ways anybody wit the solution |
muhamalak you need professional tools, there is no other way, using hot air you will destroy the mother board! |
I have replace the sim slot but now I get no signal network, what can I do? |
It is probably due to the mainboard defect, I solve many network problems by replacing IC, here is the exemplary video: |
What kind of flux should I use? |
I reccomend HF Rework Jelly Flux, very good flux for soldering on mainboard |
I need to stick the chip cover to tha mainboard, what adhesive do you reccomend? |
I also have trouble with adhesives they are mostly to weak to keep the back cover to the frame. Almost all back covers are coming off, need some solution! |
I agree. The back cover wont hold if you don't clean the frame properly, use the proper liquid. |
I need to do some soldering stuff and need leaping ways, anyone could share the scheme for it, thanks in advance. |
