10-17-2013, 15:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 74258 Status: Offline Thanks Meter: 36 | blackberry Q5 display problem |
The Following User Says Thank You to jointaccess For This Useful Post: |
11-16-2013, 08:12 | #2 (permalink) |
Major Poster Join Date: Feb 2010
Member: 1243684 Status: Offline Thanks Meter: 5 | 1. try to put only the lcd flex and check the result,,, 2. try to put another touch screen,,, 3. check up the touch screen flex connector on board,,, or the small 8pins rectangle ic besides it... |
11-16-2013, 08:19 | #3 (permalink) |
Member: 1243684 Status: Offline Thanks Meter: 5 | i have another query to ask for our members,,, i have 3 pieces Q5 now with all the same problems... it shows blackberry when u powered it on but then slowly fading off the display but the mobile is still on,,, ( it is recognized to BBlink when connected to pc) already changed new lcd and battery but still same problem,,, i already try software solution and then reworks the PM ic but still the same problem,,, any one could help??? |
01-21-2014, 09:42 | #4 (permalink) |
Junior Member Join Date: May 2007 Location: south africa
Member: 504722 Status: Offline Thanks Meter: 4 | i have same problem with q5. changed touch and phone starts up with clear screen them goes hazy. whatsbthe solution for this. i tried another lcd and same issue |
07-09-2014, 17:43 | #8 (permalink) |
Crazy Poster Join Date: Apr 2011
Member: 1565554 Status: Offline Thanks Meter: 6 | I disconnected my Q5 touch, and the phone booted up completly. keyboard working, but as the touch is disconected, i cannot use the touch. I just connected the touch with the Q5 powered on, and rebooted the phone by holding alt, caps lock and delete at the same time for few seconds. No my Q5 booted back to normal and everything works 100%. |
01-15-2015, 12:52 | #9 (permalink) |
Freak Poster Join Date: Mar 2006 Location: NIGERIA
Member: 246376 Status: Offline Thanks Meter: 11 | I have same problem, phone booted up with blackberry logo, the screen becomes scramble when trying to boot up and that's the end, I disconnected touch, use another screen, remove and gang the 3 glass display ic, still no solution. Am going to contact customer and rquest that I flash the phone. |
01-15-2015, 14:19 | #10 (permalink) |
Member: 246376 Status: Offline Thanks Meter: 11 | Just like magic, I change a new touch pad and it work. I tested without touch pad, problem persist. So problem solved by changing a new touch pad. So I will advice that you should always test with touchpad. |
07-12-2015, 18:50 | #13 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2427046 Status: Offline Thanks Meter: 0 | hello I have a Q5 is blinking a red light and I was trying to connect it on my system is requesting for ES521 signer QNXH-0S-1 if anyone who have idea on this issue should post it important. |
