Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 06-16-2012, 10:50   #1 (permalink)
R.Nasir.Ali's Avatar
Member: 1141761
Sonork: 100.1618159
blackberry solution for blinking red light 100% working
blinking red light solution for all blackberry
new and tried on 100s off bb modules success on all
1. download blackberry master control program and install it
2. download CFP_3.9.0.175.exe keep on desktop
3. open master control program and click on setting wheel on left hand side and
in enable protected control type BrickBerry same as it is here
4. right click on alien face cfp button at left hand side.
5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop.
6. connect your bb without battery on top command-line interface (CLI)
select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job.
let the bb master control be open..........
now the trick is to load os
1. In bb master control on right hand side below right click on apploader
it will loader/nojvm connect your phone follow the instruction thats it you have done the job..
please write me if you have any doubt or error
thanks
nasir
if gives you error again go to step 6 select nuke and then wipe after this if says error dont cancel the procedure just disconnect the phone remove the battery re insert and wait untill the phone finish then connect the phone and press retry
The Following 34 Users Say Thank You to R.Nasir.Ali For This Useful Post:
Old 06-16-2012, 18:27   #2 (permalink)
hector bermudez's Avatar
Member: 181405
Master control no working for me can you help me ?
Old 06-17-2012, 14:04   #3 (permalink)
Member: 1141761
Sonork: 100.1618159
master control not working
what problem r u facing use this link and instruction
BLACKBERRY_red_blinking_hangsolution by nasir.rar
The Following 6 Users Say Thank You to R.Nasir.Ali For This Useful Post:
Old 06-17-2012, 16:21   #4 (permalink)
Crazy Poster
Member: 1575227
HI ,BRO
I do not understand step 4
I can not find the CFP button
Old 06-17-2012, 16:45   #5 (permalink)
Member: 1141761
Sonork: 100.1618159
cfp botton
Originally Posted by 83632195 View Post
HI ,BRO
bro at left hand side below donate icon there are 15 icons 11th alien face icon is cfp CFP_3.9.0.175 once you right click ( BE CARE FULL RIGHT CLICK ON THAT ICON NOT JUST CLICK ) AND select wipe then select the box next to execute and execute
thanks
The Following 2 Users Say Thank You to R.Nasir.Ali For This Useful Post:
Old 06-17-2012, 18:00   #6 (permalink)
Crazy Poster
Member: 1575227
successful, BB 8520 successful !!!
THANKS
The Following 2 Users Say Thank You to 83632195 For This Useful Post:
Old 06-17-2012, 20:52   #7 (permalink)
Member: 1514695
Sonork: edward
this tutorial is for alla blackberry ???
The Following User Says Thank You to medellin_2010 For This Useful Post:
Old 06-18-2012, 07:41   #8 (permalink)
Member: 1141761
Sonork: 100.1618159
all blackberry
yes it is all most all blackberry all software complaints
with different tricks
any problem you write me i will explain you
thanks
The Following User Says Thank You to R.Nasir.Ali For This Useful Post:
Old 06-18-2012, 07:55   #9 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Dont say all blackberry, it will not rewrite missing signature in os7 devices
Old 06-18-2012, 08:01   #10 (permalink)
ren_mglab's Avatar
Member: 1501033
hi sir
can you kindly help about my blackberry 8250
problem is hang with something error.
thanks in advance
Old 06-18-2012, 08:49   #11 (permalink)
Member: 1141761
Sonork: 100.1618159
what is the problem
Originally Posted by ren_mglab View Post
hi sir
thanks in advance
what is the problem POST HERE
THANKS
NASIR
Old 06-18-2012, 10:00   #12 (permalink)
apple inside's Avatar
Member: 26011
Hi Nasir.
i have try your solution with several BB9900.
not success, actually everything is done. but it want to wipe the phone.( i have try with BB9900 only)
Old 06-18-2012, 10:14   #13 (permalink)
Member: 1141761
Sonork: 100.1618159
wipe without bettery
Originally Posted by QTEL View Post
Hi Nasir.
friend
try to wipe without battery
and remember when you select cfp select proper below in cfp options
this will appear only on right click ( right click on elian face 11th icon just right click on it
when window appear
1. select nuke then check the box next to execute and execute
2. after it finish nuke. again go up select wipe check the box next to execute
and execute
3. put the batterry back wait untill it does the job
4. right click on loader 14th icon just follow the instructions thats it
feel free to write further
thanks
Old 06-18-2012, 10:35   #14 (permalink)
Member: 26011
ok
i will give you the report withing 15 minutes. but i have try to wipe without battery
Old 06-18-2012, 10:43   #15 (permalink)
Member: 26011
Hi Nasir,
here is the result after select nuke and excute.
************** Info Dump ********************
*** Version 3.9.0.165
*** Build date: Apr 12 2011 (18:31:52)
*** Compiler: vc9
*** CMDLine: -u -v2 -t30000 -c30000 nuke
************ Info Dump END ******************
--> Using USB timeout values.
Connecting for Nuke:
--> CFP_Imp::Abort() called
--> USBDriver::Abort() called
--> FindADevice aborted
Error: ABORTED
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
Operator-Logo for 5110 MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-25-1999 15:50
Page generated in 0.36585 seconds with 12 queries
