Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 07-31-2014, 19:46   #1 (permalink)
Member: 1041037
Blackberry Z10 LCD Connector
Hello my friends
Replaced Blackberry Z10 LCD phone only showed blank screen no image, but I made a jumper and it worked just fine...After 2days the jumper went out...tried to replace the jumper, no image at all only shows a blank background till it loads the Blackberry OS then it stays black...When I connect it to the computer I can see that the phone is working...but still no image...
Any Schematics would appreciate!
Thanks
Old 01-23-2015, 23:32   #2 (permalink)
Member: 2093407
i have kind of the same problem . phone starts with iluminated blak screen, boot's up fine tap 3 times power button, voice assistant can be heared) but with no image. please help
Best regards
Old 01-24-2015, 08:46   #3 (permalink)
bablu333's Avatar
Member: 1495471
Sonork: 1603910:abubablu
Thanks Meter: 1,582
Originally Posted by FSŪ View Post
Hello my friends
Thanks
Best regards
check same verson of display.also check lc d connecter.
Old 01-26-2015, 23:38   #4 (permalink)
Member: 2093407
i have two z10 both STL 100-1 , one works as long as i keep a piece of paper between the logic board and the covering case, and the one with the display problem. i tried switching the display assembly but still no go. screen lights up for a few seconds phone boots up but no image. i looked at the lcd connector on the board and it's ok.
is there a chip that needs reheating ?
Old 01-30-2015, 08:45   #5 (permalink)
Member: 1014719
same problem.... help me master.....
Old 01-30-2015, 09:02   #6 (permalink)
Member: 25662
Thanks Meter: 190
Hi! Bro,
IN Z10 STL 100-1 where you had jumper those line please measure with multimeter you will get some of them is absent or reading is high.actually all lines must be similar.If absent or upset than that line is disconnect from cpu, by little bending you can see display.I had seen major case in STL 100-1,its board problem some where line getting disconnet or open link.No way to solve it.
Old 01-30-2015, 14:35   #7 (permalink)
bablu333's Avatar
Member: 1495471
Thanks Meter: 1,582
try this way
http://forum.gsmhosting.com/vbb/f733...bablu-1673865/
Page generated in 0.14276 seconds with 8 queries
