Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 11-29-2014, 08:56   #1 (permalink)
robin25's Avatar
Member: 771565
Sonork: 100.1656305
Thanks Meter: 145
Exclamation Blackberry z10 red battery indicator problem
Phone show blackberry and suddenly show red batter on screen
please guide me what to do phone comes with water lock
Please help me guys its urgent
The Following User Says Thank You to robin25 For This Useful Post:
Old 11-29-2014, 09:21   #2 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Did you changed battery ?
The Following User Says Thank You to Rahul_Bhutani For This Useful Post:
Old 11-29-2014, 10:06   #3 (permalink)
robin25's Avatar
Member: 771565
Sonork: 100.1656305
Thanks Meter: 145
Yes sir but still same
Old 11-29-2014, 10:19   #4 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,978
its look hardware problem
make a sure you tried with 100% good battery
If phone not water damage then you can try wipe & flash for confirm the problems .Wipe tools already posted by me
If still same check battery connector near parts !
AzimBahar/ParvezAhmed.NET
The Following 2 Users Say Thank You to aZimBahar For This Useful Post:
Old 12-02-2014, 08:59   #5 (permalink)
robin25's Avatar
Member: 771565
Sonork: 100.1656305
Thanks Meter: 145
phone is water damage
and i try autoloader or wipe but problem still same
if this is hardware problem so please tell me which part can be replaced for repair this handset
Old 12-02-2014, 09:04   #6 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
You no need check software , Cases its water damage
Its 100% hardware problem , Check & clean PCB , battery connector near parts problems
The Following User Says Thank You to aZimBahar For This Useful Post:
Old 04-28-2015, 04:57   #7 (permalink)
Member: 2385793
hi. could anybody explain this to me in a way that someone with limited knowledge on the matter would understand? for example ... i dont know what PCB is. Is this something that i can fix just by cleaning the battery or a part of the phone, or should i take it somewhere to get repaired?
Page generated in 0.21072 seconds with 8 queries
