Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 12-17-2014, 11:37   #1 (permalink)
Member: 2312186
help bb 9550 mic&buzz can`t work....
Hello ,
Please help iam have a problem bb odin/9550 mic & buzzer cannot work...
Old 12-20-2014, 16:05   #2 (permalink)
Member: 2312186
up-up-up.....please.....
Old 12-21-2014, 07:20   #3 (permalink)
Member: 25662
Thanks Meter: 190
Originally Posted by jamellacell View Post
Hello ,
Jamellacel in your case 9550
1. check does your 9550 in haedset mode than only you can't get any audio.
2. does in recording mic work?
3. buzzer (ringer) oprate from power IC and mic oprate from CPU.So it means mobile is on headset mode.Change hands free jack.
The Following User Says Thank You to Munir For This Useful Post:
Old 01-13-2015, 04:24   #4 (permalink)
Member: 2312186
Ddar mr munir
i already try with our solution but this problem still not work,any another solution.....
Old 01-13-2015, 06:26   #5 (permalink)
Member: 25662
Thanks Meter: 190
Ddar mr munir
please explain your step what you had done or check as my given step?
their after I will try to help you.
If you tried all step than check 2.6v at C1624 near power ic.Also at L1101 and L1102 near CPU.All 3 are common link,its audio volts for CPU. If both L1101 and 1102 open or broken than CPU can't get 2.6v audio volts, so their will be NO AUDIO.(you can bypass both L1101 and L1102).
If at C1624 no 2.6v than change power ic.most doubtful is L1101&L1102.
Page generated in 0.15303 seconds with 8 queries
