11-20-2012, 23:23 | #1 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1723302 Status: Offline Thanks Meter: 0 | blackberry 9300 joystick problem could you give me information about blackberry 9300joystick's if it's possible could you send me workout steps by pictures. our blackberry joystick from 9300 doesnt moves. thank you and kind regards. |
11-21-2012, 20:23 | #2 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1824591 Status: Offline Sonork: 100.1637969 Thanks Meter: 3 | Your will need to replace your joystick you can buy them cheap 1 or 2 pound. First you will need too remove the 2 screws of the back of your phone. After this remove the casing faceplate and keypad. After remove the 2 screws from on top of the lcd screen and also the other 4 below on the motherboard. Now it should be loose u can pry your motherboard out Once its out you will see the connection from the trackpad to the motherboard take out old trackpad and replace with new. Yoi can now assembke phone back togethet. If you would like phone fixed i fix phones please message mr. |
11-22-2012, 02:39 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: gsm-forum
Member: 1573913 Status: Offline Sonork: hardware illustration Thanks Meter: 7,628 | Quote:
try trick image below good luck | |
The Following User Says Thank You to d-Artigo For This Useful Post: |
