Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM) > BlackBerry Hardware Repair
Old 08-24-2015, 16:49   #1 (permalink)
Member: 1916774
Thanks Meter: 16
Q10 display
I have bb Q10, it still display ok but LCD continuous flashing screen, please help me. Thanks
Old 08-29-2015, 06:50   #2 (permalink)
Member: 25662
Thanks Meter: 190
check volts when screen flashing, which volts is vering up down.
as per picture attached.
http://forum.gsmhosting.com/vbb/f733.../#post11226513
The Following User Says Thank You to Munir For This Useful Post:
Old 08-29-2015, 16:09   #3 (permalink)
Member: 1916774
Thanks Meter: 16
All pin are ok, please give me solution
Old 08-30-2015, 06:12   #4 (permalink)
Member: 25662
Thanks Meter: 190
connect lcd power on and check all volts which one is flashing or jumping its vaule. Than only you know now which line you have trace or follow.
any voltage line creat this problem. so you have check very carefully.
Old 08-30-2015, 13:02   #5 (permalink)
Member: 1916774
Thanks Meter: 16
you see this video help me , it flashes like ripples , and 100% load , the time it does not blink at https://www.youtube.com/watch?v=u2Mx...ture=*********
The Following User Says Thank You to kem_co_102 For This Useful Post:
Old 08-31-2015, 06:34   #6 (permalink)
Member: 25662
Thanks Meter: 190
Ihad seen its happened by insufficient volt, so check carefully all volts when mobile is booting. Also check all 3 inductor L2803,L2800,L2802 and R2800 OLED_RST_N upto their pin. Does pin in socket is upset?
Old 08-31-2015, 12:58   #7 (permalink)
Member: 1916774
Thanks Meter: 16
Yes, thanks, I will do
Old 09-02-2015, 17:19   #8 (permalink)
Member: 1916774
Thanks Meter: 16
now it flashes red lights error 110, run by bblink autoload or update is not
Old 09-03-2015, 06:05   #9 (permalink)
Member: 25662
Thanks Meter: 190
If your flashes red lights error is 1111011 than it will not connect to pc. Due to emmc. I also facing same flashes red lights error. Still I can't get any solution.
Old 09-16-2015, 03:00   #10 (permalink)
Crazy Poster
Member: 2455912
Thanks Meter: 9
did'nt see any solution yet ......
Old 09-23-2015, 13:56   #11 (permalink)
ersa's Avatar
Member: 75290
Thanks Meter: 57
Q10 black LCD
Hello,
I've Q10 with black display. I found that IC(U2001) is broked. Any solution to make jumpers?
Look on atached file.
ERSA
Seb
Old 09-24-2015, 09:18   #12 (permalink)
Member: 25662
Thanks Meter: 190
Originally Posted by ersa View Post
Hello,
ERSA
Seb
U2001 is 3.1v ic. you can get it from bb 9300 network section U1206.
IC name is ADP190. first collect detail from net. than procced.
i am not responsible just giving info.
Old 08-18-2019, 08:50   #13 (permalink)
Member: 2923587
Question Help
hello guys am new here, am kindly asking for help am facing the same problem with my bb q10 sqn100-1
The Following User Says Thank You to mjoseph466 For This Useful Post:
Old 11-07-2019, 19:10   #14 (permalink)
Member: 2934203
sir pls help in blackberry Z10 ed blinkiing solution
Old 11-03-2020, 11:55   #15 (permalink)
Member: 2971281
Thanks Meter: 2
i have the same problem
Page generated in 0.24205 seconds with 9 queries
