11-06-2013, 18:35 | #1 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2060510 Status: Offline Thanks Meter: 1 | Still 75% after Wipe, Nuke, NAL and SFI I have been surfing this site for a while but I had no need to post comments up until now. Here's my story: My 9860 got stuck three weeks ago. I followed a procedure I found here (double wipe, nuke, NAL, SFI and OS loading) and the first time it worked. However, cell phone got stuck again while downloading my apps, and since then I have had no luck restarting the system. I have tried like 50 times the same procedure. Sometimes it seems like it is about to restart, but when loading bar reaches 95%, it restarts all over again, repeating this process endlessly. Some other times, it just gets stucks at 75% and does nothing. I have heard that it could be a FLASH memory problem, meaning hardware, but to be honest, I have no idea of what that could possibly be.. I am a complet ignorant when talking about electronic parts I would really appreciate any sort of help, advise or guiding you blackberry masters could give me. Thanks a lot in advance for taking the time for reading this post. Rgds and have a great day |
The Following User Says Thank You to MeMopar For This Useful Post: |
11-06-2013, 18:50 | #2 (permalink) |
Member: 2060510 Status: Offline Thanks Meter: 1 | ... Two more things I forgot to add: - Desktop Manager does not recognises the device - Loader via AppLoader does not recognises the device either the procuderure I have followed is the one you can find here on this section under the name of: "NUKE, WIPE, NAL and OS all in one script" and that is all what I have done so far... If you have any solution for this problem, please help me.... I am desperate. Thank you guys |
11-06-2013, 18:55 | #3 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: ajman U.A.E Age: 34
Member: 1805549 Status: Offline Sonork: 100.1620595 Thanks Meter: 45 | Quote:
flash with this file 100% don your phone ( after said thanks ) | |
The Following User Says Thank You to zcom For This Useful Post: |
11-06-2013, 19:40 | #6 (permalink) |
Member: 2060510 Status: Offline Thanks Meter: 1 | I just tried the loader and it does not recognises the device. Tried Desktop Manager and it does not recognises the phone either. Tried an OS loader and it went fine... but it gets stuck again around 80-85% |
11-06-2013, 19:48 | #7 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1774307 Status: Offline Thanks Meter: 224 | tool can do succes if , in the end program will show RAM IMAGE ...on white creen continue with this Spidol Monza don't forget, all process without batray Inside .. if its not work maybe Internal Memory has broken |
The Following User Says Thank You to wawan tato For This Useful Post: |
11-06-2013, 19:54 | #8 (permalink) |
Member: 2060510 Status: Offline Thanks Meter: 1 | No white screen.. just the blinking red LED light... I tried to upload OS using an uploader and same thing: 80-90%. I will try this "rapido" file and see what happens. One question: What can I do if my internal memory is damaged? Is there any chance I can repair it by myself? Should I take it to a tecnician for doing so?... Or is my cell phone dead? |
11-07-2013, 19:33 | #11 (permalink) |
Member: 2060510 Status: Offline Thanks Meter: 1 | Well, something worse happen: I followed the procedure you guys posted here. First I got stucked at 75%, but then it went black.. and now my device is dead. All I have is black screen with the red LED light on for 10 secs, then goes off... Just tell me, is it totally damaged now? |
