03-20-2015, 09:54 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 311712 Status: Offline Thanks Meter: 0 | Z10 eMMC partition problem I have a Z10 STL-2, which does not boots, autoloader runs fine and finishes without any error. HOWEVER the device does not boots. I have dumped via cfp partition and it is clearly visible there are missing partitions : Bad phone: Code: Start Block End Block HW Partition Write Protect Type -------------------------------------------------------------------------------- 0 31 Boot 0 Permanent 32 238592 User None What kind of tool can I use to make this right(autoloader does not solve this) If I unsolder the eMMC, and repair it on PC, will it work? This is the dump from OK phone: Code: Start Block End Block HW Partition Write Protect Type -------------------------------------------------------------------------------- 0 31 Boot 0 Permanent 32 671 User None 672 1311 User Temporary 1312 238592 User None Can You help me please ? |
