08-19-2014, 02:42 | #16 (permalink) |
Junior Member Join Date: Aug 2014 Location: ibadan, nigeria
Member: 2241922 Status: Offline Thanks Meter: 0 | |
10-14-2015, 18:34 | #19 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | Quote:
wbr | |
10-15-2015, 20:08 | #20 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Manila Age: 36
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 92 | hi.. try use cfp nuke -a Code: http://www.mediafire.com/download/5ddtvl3ek4kcx5v/cfp3.10.0.57.7z and then reflash u'r Blackberry 10 note : Blackberry OS 10.3.2 can't be downgrade use cfp info (if possible) to detail ur blackberry10 os version. Warning : if u reflash u'r Blackberry 10 with OS version 10.3.2,- maybe u need Blackberry ID + Password to activated u'r Device. (Blackberry Theft Protection) don't ask me about Blackberry ID + Password Do With Own Your Risk Last edited by gwlime; 10-15-2015 at 20:15. |
08-26-2016, 10:44 | #23 (permalink) |
Freak Poster Join Date: Sep 2012 Location: saudi jeddah
Member: 1814409 Status: Offline Sonork: 100.1621741 Thanks Meter: 25 | i have Z10 STL100-3 red led blink .. i flash this Autoload-STL100-3-10.3.1.997 autoloader but after flash successfully still red led blinking.anyone have any idea ? |
01-13-2017, 05:07 | #27 (permalink) |
Freak Poster Join Date: Mar 2008 Location: India, Punjab, Phagwara
Member: 731127 Status: Offline Thanks Meter: 25 | simple & best solution to this problem is to charge your battery to enough power to boot your phone to normal. it should be more than 3.7v to eliminate this red blinking problem. you can do this by charging it by external charger. after doing this you just flash it with autoloader. your device will boot normal. one thing more i want to mention that your device can't be downgraded so keep this in mind that you download upper version of the file. if you guys find this as helpful say thanx |
