07-27-2015, 07:11 | #16 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
The Following User Says Thank You to Munir For This Useful Post: |
07-27-2015, 13:07 | #17 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2434702 Status: Offline Thanks Meter: 1 | Many thanks! I found something: there was no volt on C1419 point, thus I was looking for another point with 2.85V, and I found one on C1911 (from scheme, on my panel it is pcb-46301-009). I made one short between C1419 and C1911, then plug-in through USB: the Blackberry device immediately appeared in the device manager on my PC, but after few seconds it lost. Then I disconnected the USB, run Autoload-STL100-1-DevAlphaB 10.3.1.997, re-plugged the USB and all that's fine, the program connected to phone and run completely, without any errors. While running the program, the phone did not disconnect the PC, only after the running had finished. I physically disconnected the USB, opened BB link, connected again with USB cable and started "Check updates". The BB link was found, and I started the upgrading process (it took about 30 minutes, while the device stayed connected with USB). After that if I plugged in the USB without battery the BB appeared in the BB Link and device manager for a second, then disappeared. When I inserted the battery first, after plugGED in the USB – nothing happened. When battery was in and I waited about 10 minutes and re-plugged the USB only after, also nothing happened (on PC, because at present I do not have anything, only the panel and battery). Or is it a normal reaction in such a case? |
07-27-2015, 13:36 | #18 (permalink) |
Member: 2434702 Status: Offline Thanks Meter: 1 | PS.: originally, when I plugged in USB, nothing happened anything,only sometimes it appeared in device manager for some seconds and disappeared. Is it possible that the original problem was caused by the wrong soldering of the power chip? And a simple reflow can help the situation? |
07-27-2015, 22:17 | #19 (permalink) |
Member: 2434702 Status: Offline Thanks Meter: 1 | UPDATE! after full assembled: battery in, red light on about 2-3sec and backlight on, seen Blackberry on display. After, ~5 sec, "Blackberry" is lost from screen, only backlight active and it's over |
07-28-2015, 06:34 | #20 (permalink) | |
07-29-2015, 07:46 | #21 (permalink) | |
Member: 2434702 Status: Offline Thanks Meter: 1 | Quote:
Thank you very much for the help so far, i will note from the results. | |
The Following User Says Thank You to Anakin007 For This Useful Post: |
07-30-2015, 06:11 | #22 (permalink) | |
