Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnBox Team Products > Mcnpro Light box
Old 01-31-2013, 16:34   #16 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.2.6 Released
What's new for Mcnlight box version 1.2.2.6? New!! Hot!!
Release contains:
  • Improver MTK new CPU Read /Write bugs
  • Spreadtrum reported bugs fixed
  • Spreadtrum new Flash ICs added
  • Mstar factory set function added
  • Mstar reported bugs fixed
  • Coolsand Nv data backup / Restore function added
  • Update Main software to V1.2.2.6
  • Other small report bugs fixed
Upgrading from Previous Versions:
  • As usual, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
The Following 5 Users Say Thank You to Mcnbox For This Useful Post:
Old 02-03-2013, 06:33   #17 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.2.7 Released
What's new for Mcnlight box version 1.2.2.7? New!! Hot!!
Release contains:
  • MTK new Flash ICs added
  • Fix MT625a boot detection bugs
  • Add SPD 6530A complete supported
  • Improving Mstar factory set function
  • Improving Coolsand Nv data backup / Restore function
  • Update Main software to V1.2.2.7
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 03-13-2013, 08:55   #18 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.2.9 Released
What's new for Mcnlight box version 1.2.2.9? New!! Hot!!
The full list of changes can be found here:
  • Improve Android MTK Read info & Write Function (6575 etc)
  • Fixed the big file after read can not save issue
  • CoolSand new Flash ICs added
  • Improve CoolSand Write Function
  • Spreadtrum new Flash ICs added (6530A etc)
  • Spreadtrum 6820/8810 (Add beta boot)
  • Improve Spreadtrum Write Function for new CPU
  • Improve Mstar unlock function
  • Update Box and mobile drivers to support more OS (Bit 32/64)
  • Update Main software to V1.2.2.9
  • V1.2.2.8 As Alpha testing Version by customer only, so have not public release.
The Following 2 Users Say Thank You to Mcnbox For This Useful Post:
Old 04-23-2013, 10:05   #19 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.1 Released
What's new for Mcnlight box version 1.3.0.1? New!! Hot!!
  • Improve Android MTK 657x Read & Write & Format Function
  • onekey Root function for MTK CPU Added
  • Add MTK 625A New Write Method
  • Improve CoolSand CPU bootloader
  • Add CoolSand missing bootloader
  • Spreadtrum reported Read/Write bugs fixed
  • Update Main software from V1.2.2.9 to V1.3.0.1
Old 05-18-2013, 14:02   #20 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.2 Released
What's new for Mcnlight box version 1.3.0.2? New!! Hot!!
  • Improve MTK 6583/9 Read & Write & Format Function
  • Improve MTK 6573 format function
  • Improve MTK onekey Root function
  • Update Main software to V1.3.0.2
Old 06-06-2013, 05:11   #21 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.3 Released
What's new for Mcnlight box version 1.3.0.3? New!! Hot!!
  • Improve MTK onekey Root function to be more stable
  • Fix MTK 657x Read & Write & Format Function bugs
  • SPD Android oneclick Root function added
  • SPD unlock function new method added
  • SPD Read IMEI New method added
  • SPD new flash ICs added
  • CoolSand New flash ICs added
  • CoolSand unlock function Improved
  • Android Read info function added
  • Android Reset /wipe function added
  • Android Reboot recovery function added
  • Some small reported bugs fixed
  • As usual, Version 1.3.0.3 request install version 1.3.0.1 at first,We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
The Following 3 Users Say Thank You to Mcnbox For This Useful Post:
Old 07-23-2013, 06:05   #22 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.4 Released
What's new for Mcnlight box version 1.3.0.4? New!! Hot!!
  • Boot 10 added for SPD SC6531
  • Android Read info function Improved
  • Android wipe function Improved
  • Update Main Installer to 1.3.0.4
Old 08-02-2013, 11:59   #23 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.5 Released
What's new for Mcnlight box version 1.3.0.5? New!! Hot!!
  • SPD SC6531 bootloader improved
  • SPD SC65xx IMEI function improved
  • SPD 6820 /8810 full improved
  • CoolSand new flash ICs added
  • Update Main Installer to 1.3.0.5
  • As usual, Version 1.3.0.5 request install version 1.3.0.4 at first,, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
Old 11-07-2013, 08:01   #24 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.7 Released
What's new for Mcnlight box version 1.3.0.7? New!! Hot!!
  • MTK android code erase function added
  • MTK R/W NV data function improved
  • SPD new flash ICs added for 6820 /8810
  • SPD ADB backup function added
  • Many small reported bugs fixed
  • Update Main Installer to 1.3.0.7
  • As usual, Version 1.3.0.7 request install version 1.3.0.4 at first,, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
Old 01-24-2014, 07:31   #25 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.8 Released
What's new for Mcnlight box version 1.3.0.8? New!! Hot!!
  • MTK android New write method function added
  • MTK android write EMMC Flash improved
  • MTK New flash ICs added (eg. 6572 Nand Flash)
  • Spreadtrum 885x original flash files like *.gz type add supported
  • Spreadtrum ADB ROOT function improved
  • Spreadtrum IMEI Detection New method Added
  • Spreadtrum new Flash ICs added (8810/6820 etc)
  • Spreadtrum 8810/6820 W/R Full Flash add supported
  • Spreadtrum 8810/6820 safe format function added
  • Spreadtrum 8810/6820 Root/ Nv data function full improved
  • Spreadtrum 6531A format now supported
  • CoolSand reported bugs fixed
  • Update Main Installer to 1.3.0.8
  • As usual, Version 1.3.0.8 request install version 1.3.0.4 at first,, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
Old 02-24-2014, 13:11   #26 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.0.9 Released
What's new for Mcnlight box version 1.3.0.9? New!! Hot!!
  • MTK android IMEI Change function improved
  • MTK New flash ICs added (New Nand Flash)
  • Android Pattern code direct read function added
  • Spreadtrum 8810/6820 safe format function improved
  • Spreadtrum 8810/6820 New Flash ICs added
  • Spreadtrum 653x function improved
  • Update Main Installer to 1.3.0.9
  • As usual, Version 1.3.0.9 request install version 1.3.0.4 at first,, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
Old 07-26-2014, 15:17   #27 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.1.0 Released
What's new for Mcnlight box version 1.3.1.0? New!! Hot!!
  • MTK add 65xx (6575/77/89/92) supported
  • MTK Nand Read/Write Flash improved
  • MTK Unlock function add new method
  • MTK Android format function improved
  • Spreadtrum 6531 Now supported
  • Spreadtrum Add SC6500 supported
  • Android Pattern Code unlock improved
  • Android add ADB Root
  • Android add google lock remove function
  • Android Wipe ,Reset Gmail, Reboot recovery function updated
  • As usual, Version 1.3.1.0 request install version 1.3.0.4 at first,, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version. New completed installer we will release on monday.
Old 01-30-2015, 23:51   #28 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.1.2 Released
What's new for Mcnlight box version 1.3.1.2 ?
  • MTK add new flash IC supported
  • MTK Android write Nand Flash improved
  • MTK 6260 Read /Write improved
  • Spreadtrum 8810/6820 Format /Unlock improved
  • Spreadtrum Add SC6500 New Flash ICs added
  • Spreadtrum Add SC6500 Format improved
  • Spreadtrum Add SC65xx read function improved
  • Spreadtrum Add SC6531 Format improved
  • Spreadtrum Add SC6531 New Flash ICs added
  • As usual, Version 1.3.1.2 request install using last installer version at first,, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.32554 seconds with 10 queries
