Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnBox Team Products > Mcnpro Light box
Old 05-19-2012, 19:44   #1 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.3.1.2 Released
What's new for Mcnlight box version 1.2.0.8 ? New!!
  • This is bugs fixed release,As usual, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from Support Section!
The Following 13 Users Say Thank You to Mcnbox For This Useful Post:
Old 05-23-2012, 16:09   #2 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro light Box official version 1.2.0.9 Released
What's new for Mcnlight box version 1.2.0.9 ? New!! Hot!!
  • Add CoolSand CPU Read function
  • Add CoolSand CPU Write function
  • Add CoolSand CPU Format function
  • Add CoolSand CPU Unlock function
  • Add CoolSand CPU IMEI Change Function (First in the world)
  • Improved MTK 6573/6516/6513 read /write
  • Fix Nor flash write bugs for boot6
  • Fix MTK safe format issue
  • Improved Tubro mode flash phone speed
  • Improved MTK USB Pin-find function
  • Improved Spreadtrum 6800H read /write
  • Add support Spreadtrum 880xG
  • Improved Spreadtrum direct IMEI change function
  • Spreadtrum new Flash ICs added
  • Fix Mstar read /write bugs
  • Other small report bugs fixed
22:24:46 Welcome to use McnPro light Box
22:24:46 Baud setting ...
22:24:51 Set Baud done
22:24:51 SW V12.09
22:24:51 FW V2.04
22:24:51 SN MCNL8888888888888
22:24:51 AC 8888-8888-8888-8888-8888
22:24:51 Box Connected!
Upgrading from Previous Versions:
  • As usual, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section !
The Following 8 Users Say Thank You to Mcnbox For This Useful Post:
Old 06-04-2012, 20:48   #3 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.0 Released
What's new for Mcnlight box version 1.2.1.0 ? New!! Hot!!
  • Improve CoolSand CPU Read /Write Function
  • Improve CoolSand CPU IMEI Change Function
  • Update Main software version to 1.2.1.0
22:24:51 SW V12.10
22:24:51 FW V2.04
The Following 4 Users Say Thank You to Mcnbox For This Useful Post:
Old 06-16-2012, 17:34   #4 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.2 Released
What's new for Mcnlight box version 1.2.1.2 ? New!! Hot!!
  • Improved CoolSand Read /Write (Full Support) Hot!!
  • Improved Spreadtrum 6800H read /write/format (Full Support) Hot!!
  • Improved Spreadtrum 880XG boot loader
  • Improved Mstar read /write bugs
  • Update Main software to V1.2.1.2
  • Update Box Firmware to V2.05
22:24:51 SW V12.12
22:24:51 FW V2.05
  • As usual, We recommend that all customers running previous versions now upgrade to new version which is available for all customers with valid, To download that from support section ! You also can using Updater direct upgrade to last version.
The Following User Says Thank You to Mcnbox For This Useful Post:
Old 07-07-2012, 13:56   #5 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Mcnpro light Box official version 1.2.1.3 Released
What's new for Mcnlight box version 1.2.1.3 ? New!! Hot!!
  • CoolSand new Flash ICs added
  • Update Main software to V1.2.1.3
  • Update Box Firmware to V2.06
20:32:38 Welcome to use McnPro light Box
20:32:39 Baud setting ...
20:32:40 Set Baud done
20:32:41 SW V12.13
20:32:41 FW V2.06
20:32:41 SN MCNL8888888888888
20:32:41 AC 8888-8888-8888-8888-8888
20:32:41 Box Connected!
The Following 3 Users Say Thank You to Mcnbox For This Useful Post:
Old 07-27-2012, 19:10   #6 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.4 Released
What's new for Mcnlight box version 1.2.1.4 ? New!! Hot!!
  • MT62xx (6276 /6255) read/write bugs fixed
  • MT65xx CPU (6573/6516/6575/6577) complete supported Hot!!
  • MTK Auto format bug fixed
  • CoolSand CPU Read /Write bugs fixed
  • CoolSand new flash ICs added
  • Spreadtrum 6800H read/write bugs fixed
  • Spreadtrum New flash ICs added
  • Mstar new Flash ICs added
  • Update Main software to V1.2.1.4
Old 08-09-2012, 11:20   #7 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.5 Released
What's new for Mcnlight box version 1.2.1.5 ? New!! Hot!!
  • MTK 65xx bugs fixed
  • MTK new Flash ICs added
  • Improved MTK USB read /write bugs
  • Update Main software to V1.2.1.5
Old 08-14-2012, 09:04   #8 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.6 Released
What's new for Mcnlight box version 1.2.1.6 ? New!! Hot!!
  • MTK 6252 bugs fixed (IMEI / Read / Write etc)
  • Update Main software to V1.2.1.6
Old 08-26-2012, 15:49   #9 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.7 Released
What's new for Mcnlight box version 1.2.1.7 ? New!! Hot!!
  • Spreadtrum unlock function Improved
  • CoolSand unlock function Improved
  • Mstar 8532B/33BX read /write Improved (Full Support) Hot!!
  • Update Main software to V1.2.1.7
  • Box Firmware upgrade to V3.09
22:46:23 Welcome to use McnPro light Box
22:46:23 Baud setting ...
22:46:25 Set Baud done
22:46:25 SW V12.17
22:46:25 FW 3.09
22:46:25 SN MCNLxxxxxxxxxxxx
22:46:25 AC xxxx-xxxx-xxxx-xxxx-xxxx
22:46:25 Box Connected!
Old 09-05-2012, 12:00   #10 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.8 Released
What's new for Mcnlight box version 1.2.1.8 ? New!! Hot!!
  • USB Cable stand function added
  • Update Main software to V1.2.1.8
What is USB CABLE stand function ?
  • Using stand USB cable operational any related procedure without Pinout Define;
  • Manual define the USB pinout , then using USB cable operational any related procedure;
Old 09-11-2012, 10:13   #11 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.1.9 Released
What's new for Mcnlight box version 1.2.1.9 ? New!! Hot!!
  • USB Cable stand function improved
  • CoolSand reported bugs fixed
  • Mstar unlock function improved
  • MTK 6250/6252A read/write Improved
  • MTK new test boot update to new version
  • MTK Android phone IMEI Change/repair function added
  • Add support Spreadtrum SC6530 (AMD32-128,SPANSION,Samsung,INTEL,Numonyx,SST,TSB,CFEON etc)
  • Update Main software to V1.2.1.9
Old 10-02-2012, 15:43   #12 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.2.0 Released
What's new for Mcnlight box version 1.2.2.0 ? New!! Hot!!
  • MTK IMEI Change Power On/Off Mode function Improved
  • MTK unlock function new method added
  • CoolSand IMEI Change new method added
  • Update Main software to V1.2.2.0
The Following 7 Users Say Thank You to Mcnbox For This Useful Post:
Old 12-02-2012, 10:47   #13 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.2.3 Released
What's new for Mcnlight box version 1.2.2.3 ? New!! Hot!!
Release contains:
  • MTK bootloader update to support new CPU
  • Fixed MTK write bugs for some special ICs
  • Spreadtrum add support Andriod base phone (Read/write/Unlock/IMEI Change)
  • Spreadtrum Unlock function improved
  • Fixed Mstar write flash bugs
  • Mstar Unlock function improved
  • Update Main software to V1.2.2.3
    18:21:04 Welcome to use McnPro light Box
    18:21:04 Baud setting ...
    18:21:09 Set Baud done
    18:21:09 SW V12.23
    18:21:09 FW 3.09
    18:21:09 SN MCNLxxxxxxxxxxxxxx
    18:21:09 AC 8888-8888-8888-8888-8888
    18:21:09 Box Connected!
Old 12-13-2012, 21:30   #14 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.2.4 Released
What's new for Mcnlight box version 1.2.2.4? New!! Hot!!
Release contains:
  • Improve Android MTK Read info & Write Function
  • Standard Android platform added (Beta) Hot!!
    • Support IMEI Change
    • Support Clear Screen Lock
  • Update Main software to V1.2.2.4
The Following 2 Users Say Thank You to Mcnbox For This Useful Post:
Old 12-31-2012, 16:45   #15 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
Arrow Mcnpro light Box official version 1.2.2.5 Released
What's new for Mcnlight box version 1.2.2.5? New!! Hot!!
Release contains:
  • Improve Standard Android platform Hot!!
  • Spreadtrum Read & Write reported bugs fixed
  • Update Main software to V1.2.2.5
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 03:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.60003 seconds with 8 queries
