Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnBox Team Products > Mcnpro Light box
Old 11-27-2012, 17:27   #1 (permalink)
Member: 1101186
McnPro light Box problem (->ANSWERDE)
When you try to read the phone book, the box says Maybe PC USB power not enough. Ports changed, on other computers, the result is the same. Similarly, behave and other options on this tab. How to solve this problem? log:
18:12:25 Welcome to use McnPro light Box
18:12:25 Baud setting ...
18:12:26 Set Baud done
18:12:26 SW V12.20
18:12:26 FW 3,09
18:12:26 SN
18:12:26 AC
18:12:26 Box Connected!
18:12:29 Chip Scaning,Press and HOLD Power button now !
18:12:29 <<..#..
18:12:36 CPU: MT6226BA
18:12:36 pinouts: Rx:1 Tx:3 Gnd:10
18:12:38 Pinout Applied
18:12:48 Pinout Applied
18:12:48 Press and HOLD Power button now
18:12:51 None MW
18:12:51 CPUЈєMT6226 Ver: 8A02 SW:8A01
18:13:01 Device enter test mode,error
18:13:01 Maybe PC USB power not enough
Old 11-29-2012, 02:29   #2 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
try adjust baud rate speed & change boot ...
The Following User Says Thank You to MARVZ_TG For This Useful Post:
Old 11-30-2012, 11:44   #3 (permalink)
Member: 1101186
I've included all of the download speed. The same result. When the phone is placed in test mode, its consumption increases to 1 ampere. The same happens on other phones. This is a faulty box? Or is it a software glitch on the manufacturer?
Old 11-30-2012, 11:49   #4 (permalink)
Mcnbox's Avatar
Member: 726283
Sonork: 100.76027
Thanks Meter: 7,616
We will post new upgrade tomorrow if ready, hope you can give a report once you test !
Best regards !
Mcnbox
The Following 3 Users Say Thank You to Mcnbox For This Useful Post:
Old 12-02-2012, 22:29   #5 (permalink)
Member: 1101186
Thank you. Very good update. Search pins and connection via USB cable is much better. Works well with the CPU: MT625Ayu But there's a problem, I can not be authorized for support. I keep getting the answer:
Sorry, Please double confirm the serial number and activation code.
Box serial number and activation code did not match.
The serial number and activation code already activated by other member.
The serial number and activation code did not found in database.
Tell me, how do I get the product activation?
Old 12-02-2012, 22:35   #6 (permalink)
Member: 1101186
typo MT625Ayu-MT625A
Old 07-19-2013, 20:34   #7 (permalink)
Member: 891091
Sonork: wonk
Thanks Meter: 5
MTK 6253 same usb not enough <mcn light pro>
where the solution please...wait,,,,always,mcn team...
Page generated in 0.16118 seconds with 9 queries
