Successfully unlocked/repaired phones by Mcnpro light Box ! M519 6600H Read: Code: 18:48:28 Welcome to use McnPro light Box Write: Code: 18:55:46 Definition Applied Unlock: Code: 19:00:35 Definition Applied |
Format: Code: 22:39:54 Definition Applied |
K-Touch M610 Mstar MSW853X Read: Code: 23:00:51 Box Connected! Write: Code: 23:06:02 Definition Applied Format: Code: 23:20:54 Definition Applied |
Successfully unlocked/repaired phones by Mcnpro light Box ! 01:03:43 Welcome to use McnPro light Box 01:03:43 Baud setting ... 01:03:45 Set Baud done 01:03:45 SW V12.08 01:03:45 FW V2.04 01:03:45 SN MCNLxxxxxxxxxxx 01:03:45 AC xxxxxxxxxxxxxxx 01:03:45 Box Connected! 01:03:54 SPD Pinout Scaning... 01:03:54 <<. 01:03:58 CPU: Spread 01:03:58 pinouts: D+:10 D-:9 Gnd:8 01:03:59 Pinout Applied 01:05:43 Scanning USB Serial port... 01:06:12 SU2Serial Port: COM13 01:06:12 Connecting, wait... 01:06:12 Done. 01:06:12 Info:Spreadtrum Boot Block version 2.0 01:06:12 Automatic mode 01:06:12 Initialize boot,Wait.. 01:06:15 Boot Done. 01:06:15 Setting baudrate... 01:06:16 Set Baud 921600 Done 01:06:16 CPU Type 6600M/E 01:06:16 Flash Type NOR 01:06:16 Flash ID 00EC257E(25082501) 01:06:16 Flash Model K5L2931CAM 01:06:16 Flash Size 0x1000000(16.0M) 01:06:16 Reading,Wait... 01:07:23 Read Done. 01:07:30 File saved:C:\Users\Dharya\Desktop\mcn\6600M_E_K5L2931C AM.bin |
01:22:35 Pinout Applied 01:22:35 Scanning USB Serial port... 01:22:57 SU2Serial Port: COM13 01:22:57 Connecting, wait... 01:22:57 Done. 01:22:57 Info:Spreadtrum Boot Block version 2.0 01:22:57 Automatic mode 01:22:57 Initialize boot,Wait.. 01:22:59 Boot Done. 01:22:59 Setting baudrate... 01:23:00 Set Baud 921600 Done 01:23:00 CPU Type 6600M/E 01:23:00 Flash Type NOR 01:23:00 Flash ID 00EC257E(25082501) 01:23:00 Flash Model K5L2931CAM 01:23:00 Flash Size 0x1000000(16.0M) 01:23:00 Writing,Wait.. 01:27:00 Write Done. |
01:27:03 Pinout Applied 01:27:03 Scanning USB Serial port... 01:27:36 SU2Serial Port: COM13 01:27:36 Connecting, wait... 01:27:37 Done. 01:27:37 Info:Spreadtrum Boot Block version 2.0 01:27:37 Automatic mode 01:27:37 Initialize boot,Wait.. 01:27:39 Boot Done. 01:27:39 Setting baudrate... 01:27:40 Set Baud 921600 Done 01:27:40 CPU Type 6600M/E 01:27:40 Flash Type NOR 01:27:40 Flash ID 00EC257E(25082501) 01:27:40 Flash Model K5L2931CAM 01:27:40 Flash Size 0x1000000(16.0M) 01:27:40 Starting,Wait... 01:27:48 User code: 1234 |
01:29:31 Pinout Applied 01:29:31 Scanning USB Serial port... 01:30:02 SU2Serial Port: COM13 01:30:02 Connecting, wait... 01:30:03 Done. 01:30:03 Info:Spreadtrum Boot Block version 2.0 01:30:03 Automatic mode 01:30:03 Initialize boot,Wait.. 01:30:05 Boot Done. 01:30:05 Setting baudrate... 01:30:06 Set Baud 921600 Done 01:30:06 CPU Type 6600M/E 01:30:06 Flash Type NOR 01:30:06 Flash ID 00EC257E(25082501) 01:30:06 Flash Model K5L2931CAM 01:30:06 Flash Size 0x1000000(16.0M) 01:30:06 Check Flash info,Wait... 01:30:13 Done.! 01:30:13 Formating... 01:30:13 Start Addr:E00000 Size:1F0000 01:30:26 Format Completed. |
Successfully unlocked/repaired phones by Mcnpro light Box ! 01:56:29 Welcome to use McnPro light Box 01:56:29 Baud setting ... 01:56:30 Set Baud done 01:56:30 SW V12.08 01:56:30 FW V2.04 01:56:30 SN MCNLxxxxxxxxxxx 01:56:30 AC xxxxxxxxxxxxxxxxx 01:56:30 Box Connected! 01:56:39 SPD Pinout Scaning... 01:56:39 <<. 01:56:43 CPU: Spread 01:56:43 pinouts: D+:9 D-:8 Gnd:1 01:56:44 Pinout Applied 01:56:44 Scanning USB Serial port... 01:56:48 SU2Serial Port: COM4 01:56:48 Connecting, wait... 01:56:48 Done. 01:56:48 Info:Spreadtrum Boot Block version 2.0 01:56:48 Automatic mode 01:56:48 Initialize boot,Wait.. 01:56:51 Pinout Applied 01:56:52 Scanning USB Serial port... 01:56:56 SU2Serial Port: COM4 01:56:56 Connecting, wait... 01:56:56 Done. 01:56:56 Info:Spreadtrum Boot Block version 2.0 01:56:56 Initialize boot6... 01:56:58 CPU Type 6600L/WT6226 01:56:58 Flash Type NOR 01:56:58 Flash ID 00EC257E(25082501) 01:56:58 Flash Model K5L2931CAM 01:56:58 Flash Size 0x1000000(16.0M) 01:56:58 Reading,Wait... 01:59:21 Read Done. 01:59:45 File saved:D:\mcnfile\6600L_WT6226_K5L2931CAM.bin 02:00:04 Pinout Applied 02:00:04 Scanning USB Serial port... 02:00:07 SU2Serial Port: COM4 02:00:07 Connecting, wait... 02:00:08 Done. 02:00:08 Info:Spreadtrum Boot Block version 2.0 02:00:08 Automatic mode 02:00:08 Initialize boot,Wait.. 02:00:11 Pinout Applied 02:00:12 Scanning USB Serial port... 02:00:15 SU2Serial Port: COM4 02:00:15 Connecting, wait... 02:00:16 Done. 02:00:16 Info:Spreadtrum Boot Block version 2.0 02:00:16 Initialize boot6... 02:00:17 CPU Type 6600L/WT6226 02:00:17 Flash Type NOR 02:00:17 Flash ID 00EC257E(25082501) 02:00:17 Flash Model K5L2931CAM 02:00:17 Flash Size 0x1000000(16.0M) 02:00:17 Writing,Wait... 02:08:20 Write Done. 02:13:37 Pinout Applied 02:13:37 Scanning USB Serial port... 02:13:41 SU2Serial Port: COM4 02:13:41 Connecting, wait... 02:13:41 Done. 02:13:41 Info:Spreadtrum Boot Block version 2.0 02:13:41 Automatic mode 02:13:41 Initialize boot,Wait.. 02:13:44 Pinout Applied 02:13:45 Scanning USB Serial port... 02:13:48 SU2Serial Port: COM4 02:13:48 Connecting, wait... 02:13:49 Done. 02:13:49 Info:Spreadtrum Boot Block version 2.0 02:13:49 Initialize boot6... 02:13:50 CPU Type 6600L/WT6226 02:13:50 Flash Type NOR 02:13:50 Flash ID 00EC257E(25082501) 02:13:50 Flash Model K5L2931CAM 02:13:50 Flash Size 0x1000000(16.0M) 02:13:50 Starting,Wait... 02:14:07 IMEI1 :111111111111111 02:14:07 IMEI2 :222222222222222 02:14:07 Screen Code:1114 02:14:07 Screen Code:1112 02:14:07 Screen Code:1111 02:14:07 Privacy code:1234 |
02:15:07 Pinout Applied 02:15:08 Scanning USB Serial port... 02:15:11 SU2Serial Port: COM4 02:15:11 Connecting, wait... 02:15:12 Done. 02:15:12 Info:Spreadtrum Boot Block version 2.0 02:15:12 Initialize boot6... 02:15:14 CPU Type 6600L/WT6226 02:15:14 Flash Type NOR 02:15:14 Flash ID 00EC257E(25082501) 02:15:14 Flash Model K5L2931CAM 02:15:14 Flash Size 0x1000000(16.0M) 02:15:14 Check Flash info,Wait... 02:16:52 Done.! 02:16:52 Formating... 02:16:52 Format Completed. |
Successfully unlocked/repaired phones by Mcnpro light Box ! 12:48:52 Welcome to use McnPro light Box 12:48:52 Baud setting ... 12:48:54 Set Baud done 12:48:54 SW V12.09 12:48:54 FW V2.04 12:48:54 SN MCNL0204xxxxx 12:48:54 AC xxxx-xxxxx 12:48:54 Box Connected! 12:49:10 Chip Scaning,Press and HOLD Power button now ! 12:49:10 <<.......... 12:51:18 User Abort 12:51:21 SPD Pinout Scaning... 12:51:21 <<....... 12:52:05 User Abort 12:52:08 MTK Pinout Scaning,Press and HOLD Power button now ! 12:52:08 <<# 12:52:11 CPU: MT6253 12:52:11 pinouts: Rx:7 Tx:6 Gnd:1 Vcc:3 12:52:11 Pinout Applied 12:52:12 Press and HOLD Power button now 12:52:14 Release power button now ! 12:52:14 CPU: MT6253 [8A04 :8A00] 12:52:16 Initialize boot 6 ... 12:52:45 Nor Flash ID 00898903 12:52:45 Nor Flash Size 1000000 12:52:45 Verifying Baud... 12:52:45 Set Baudrate to 921600 12:52:45 Reading,Wait... 12:56:09 Done. 12:56:33 File saved:C:\Users\D\Desktop\1\MTK_6253_00898903.bin 12:59:11 Pinout Applied 12:59:12 >> 12:59:12 Press and HOLD Power button now 12:59:16 Release power button now ! 12:59:16 CPU: MT6253 [8A04 :8A00] 12:59:19 Initialize boot 6 ... 12:59:47 Nor Flash ID 00898903 12:59:47 Nor Flash Size 1000000 12:59:48 Verifying Baud... 12:59:48 Set Baudrate to 921600 12:59:48 Eraseing Flash... 13:00:09 Writing,Wait... 13:04:06 Done. 13:08:13 Pinout Applied 13:08:13 Press and HOLD Power button now 13:08:17 CPU:MT6253 Ver: 8A04 SW:8A00 13:08:26 Read Information From the Phone... 13:08:49 Unlock code 1122 13:08:49 Done http://img39.imageshack.us/img39/999...3008989032.jpg http://img39.imageshack.us/img39/999...3008989032.jpg http://img513.imageshack.us/img513/3...3008989034.jpg thanks mcn team |
Very good, bad factory problem fixed 14:23:16 CPU:MT6253 Ver: 8A04 SW:8A00 14:23:22 Read Information From the Phone... 14:23:22 Info:MT6253_T022_1A_T_YIHUA_V13_HEXING53_10A_GEMIN IPLUS_HW_Melody_V0.0 14:23:31 Done. |
Coolsand CPU W25Q64CV Model:RT6 All Done 18:06:48 Welcome to use McnPro light Box 18:06:48 Baud setting ... 18:06:49 Set Baud done 18:06:49 SW V12.09 18:06:49 FW V2.04 18:06:49 SN MCNL888888888888 18:06:49 AC 8888-8888-8888-8888-8888 18:06:49 Box Connected! 18:07:03 CoolSand Pinout Scaning,Press and HOLD Power button now ! 18:07:03 << 18:07:13 CPU: CoolSand 18:07:13 pinouts: Rx:7 Tx:6 Gnd:9 Vcc:1 18:07:14 Pinout Applied 18:07:14 Phone detected, Wait... 18:07:15 Done. 18:07:15 CPU Type Coolsand 18:07:15 Flash Type NOR 18:07:15 Flash ID 00EF0040(00170000) 18:07:15 Flash Model W25Q64CV 18:07:15 Flash Size 0x800000(8.0M) 18:07:15 Reading,Wait... 18:23:16 Read Done. 18:23:22 File saved:C:\Users\D\Desktop\1\Coolsand_W25Q64CV.bin 18:24:42 Pinout Applied 18:24:42 Phone detected, Wait... 18:24:42 Done. 18:24:43 Initialize boot,Wait... 18:24:45 CPU Type Coolsand 18:24:45 Flash Type NOR 18:24:45 Flash ID 00EF0040(00170000) 18:24:45 Flash Model W25Q64CV 18:24:45 Flash Size 0x800000(8.0M) 18:24:45 Writing,Wait... 18:38:27 Done. 18:39:26 Pinout Applied 18:39:26 Phone detected, Wait... 18:39:27 Done. 18:39:27 CPU Type Coolsand 18:39:27 Flash Type NOR 18:39:27 Flash ID 00EF0040(00170000) 18:39:27 Flash Model W25Q64CV 18:39:27 Flash Size 0x800000(8.0M) 18:39:27 Starting,Wait... 18:41:37 No password found |
Successfully unlocked/repaired phones by Mcnpro light Box ! http://i499.photobucket.com/albums/r...nge-dallas.jpg pinout dection in 2SEC SO WITH MCNLIGHT FORGET SOLDERING http://i499.photobucket.com/albums/r.../1PINOUTOK.jpg READING IN FEW SECOND NO COMMENT http://i499.photobucket.com/albums/r...3/2READING.jpg |
Successfully unlocked/repaired phones by Mcnpro light Box ! FORMAT DONE WITH AUTO SAVED LCD DATA :) http://i499.photobucket.com/albums/r...3/2IMEIE71.jpg WRITTEN 2EMEI OK http://i499.photobucket.com/albums/r...2IMEIE71-1.jpg |
Z90 spd cpu 6600 look PINOUT OK http://i499.photobucket.com/albums/r...PINOUT2SEC.jpg UNLOCK OK SO FAST http://i499.photobucket.com/albums/r...NLOCK30SEC.jpg |
