Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > McnBox Team Products > Mcnpro Light box
Old 09-21-2012, 01:24   #46 (permalink)
MARVZ_TG's Avatar
Member: 990711
Sonork: 100.1597405
Thanks Meter: 1,779
IPHONE4 CHINA PHONE (READ -PASS CODE- DONE) CPU Type 6803
*.NO NEED TO CHANGE BAUDRATE
*.NO NEED TO CHANGE BOOT
*.JUST SELECT AUTO
PROCEDURE
1. READ FLASH
2. ANALYSIS CODE
DONE
BR.MARVZ_TG
Old 12-03-2012, 14:05   #47 (permalink)
MDK23's Avatar
Member: 467636
Sonork: Double Kanon
Thanks Meter: 2,654
Smile Cpu: Mt6250
20:14:55 Chip Scaning,Press and HOLD Power button now !
20:14:55 <<
20:15:01 CPU: MT6250
20:15:01 pinouts: Rx:5 Tx:3 Gnd:10 Vcc:1
20:15:02 Pinout Applied
20:15:05 Pinout Applied
20:15:06 Press and HOLD Power button now
20:15:14 Pinout Applied
20:15:14 Press and HOLD Power button now
20:15:18 Release power button now !
20:15:18 CPU: MT6252A(6250) [CF00 :0101]
20:15:18 Initialize boot 7 ...
20:15:30 Nor Flash ID 00EF0060(00170000)
20:15:30 Nor Flash Size 800000
20:15:30 Verifying Baud...
20:15:30 Set Baudrate to 921600
20:15:30 Reading,Wait...
20:15:30 Info:
20:15:30 PROWAVE52_BU3_6432_10A_PCB01_GPRS_MT6252_S01.XD_S5 98_53_HW23_5876_HB_AF_V1_1.BIN_FLNW25Q64DWZPIG
20:15:30 Device security area#1 is Ok
20:15:30 Keep Waiting...
20:17:12 Done.
18:23:04 CPU: MT6250
18:23:04 pinouts: Rx:5 Tx:3 Gnd:10
18:23:05 Pinout Applied
18:23:15 Pinout Applied
18:23:15 You can customize format address
18:23:15 Press and HOLD Power button now
18:23:17 User Abort
18:23:20 Pinout Applied
18:23:20 Press and HOLD Power button now
18:23:24 Release power button now !
18:23:24 CPU: MT6252A(6250) [CF00 :0101]
18:23:25 Initialize boot 7 ...
18:23:36 Nor Flash ID 00EF0060(00170000)
18:23:36 Nor Flash Size 800000
18:23:36 Verifying Baud...
18:23:36 Set Baudrate to 921600
18:23:36 Reading,Wait...
18:23:37 Info:
18:23:37 PROWAVE52_BU3_6432_10A_PCB01_GPRS_MT6252_S01.XD_S5 98_53_HW23_5876_HB_AF_V1_1.BIN_FLNW25Q64DWZPIG
18:23:37 Device security area#1 is Ok
18:23:37 Keep Waiting...
18:25:17 Done.
18:25:25 File saved:C:\Documents and Settings\MdK\Bureau\PROWAVE52_BU3_6432_10A_PCB01_G PRS_MT6252_S01.XD_S598_53_HW23_5876_HB_AF_V1_1.BIN _FLNW25Q64DWZPIG
18:25:32 Pinout Applied
18:25:32 You can customize format address
18:25:33 Press and HOLD Power button now
18:25:36 Release power button now !
18:25:36 CPU: MT6252A(6250) [CF00 :0101]
18:25:37 Initialize boot 7 ...
18:25:48 Nor Flash ID 00EF0060(00170000)
18:25:48 Nor Flash Size 800000
18:25:53 Formating...
18:25:53 Format Satrt Addr£؛0x768000, Size: 0x98000
18:25:58 Done.
The Following 2 Users Say Thank You to MDK23 For This Useful Post:
Old 12-20-2012, 19:12   #48 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
Smile I9100 mtk 6252 by mcnlight
REDING FULL FLASH BY USB
18:58:29 Chip Scaning,Press and HOLD Power button now !
18:58:29 <<
18:58:33 PID&VID: 0E8D0003
18:58:33 pinouts: D+:3 D-:4 Gnd:1
18:58:34 Pinout Applied
18:58:41 Searching USB to Serial Port...
18:59:11 Port:COM77
18:59:11 Press and HOLD Power button now
18:59:12 Unstable USB port
18:59:18 Chip Scaning,Press and HOLD Power button now !
18:59:18 <<
18:59:22 PID&VID: 0E8D0003
18:59:22 pinouts: D+:3 D-:4 Gnd:1
18:59:23 Pinout Applied
18:59:27 Pinout Applied
18:59:27 Searching USB to Serial Port...
18:59:30 Port:COM77
18:59:30 Press and HOLD Power button now
18:59:32 Connected to Phone.
18:59:32 CPU: MT6250DA(625A) Ver: CA01 :0001]
18:59:35 Initialize boot 7 ...
18:59:39 Nor Flash ID 00C80060(00180000)
18:59:39 Nor Flash Size 1000000
18:59:39 Reading,Wait...
18:59:40 Info:
18:59:40 GM50_6464_11B_PCB01_GPRS_MT6250_S00.R5001_L14_TY9100.BIN
18:59:40 Device security area#1 is Ok
18:59:40 Keep Waiting...
19:00:24 Done.
19:00:30 File saved:C:\Documents and Settings\MdK\Bureau\GM50_6464_11B_PCB01_GPRS_MT6250_S00.R5001_L1
FORMAT OK
19:07:42 Chip Scaning,Press and HOLD Power button now !
19:07:42 <<.
19:07:46 PID&VID: 0E8D0003
19:07:46 pinouts: D+:3 D-:4 Gnd:1
19:07:47 Pinout Applied
19:07:53 Pinout Applied
19:07:53 You can customize format address
19:07:53 Searching USB to Serial Port...
19:07:54 Port:COM77
19:07:54 Press and HOLD Power button now
19:07:56 Connected to Phone.
19:07:56 CPU: MT6250DA(625A) Ver: CA01 :0001]
19:07:59 Initialize boot 7 ...
19:08:03 Nor Flash ID 00C80060(00180000)
19:08:03 Nor Flash Size 1000000
19:08:04 Formating...
19:08:04 Format Satrt Addr£؛0xE80000, Size: 0x180000
19:08:14 Done.
The Following User Says Thank You to MDK23 For This Useful Post:
Old 12-25-2012, 20:16   #49 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
Smile Mtk 6253 ok by mcnboxlight
20:01:31 Chip Scaning,Press and HOLD Power button now !
20:01:31 <<#
20:01:35 CPU: MT6253
20:01:35 pinouts: Rx:4 Tx:6 Gnd:3 Vcc:1
20:01:37 Pinout Applied
20:01:41 Pinout Applied
20:01:42 Press and HOLD Power button now
20:01:45 Release power button now !
20:01:45 CPU: MT6253 [8A04 :8A00]
20:01:48 Initialize boot 7 ...
20:02:19 Nor Flash ID 0098009E
20:02:19 Nor Flash Size 1000000
20:02:19 Verifying Baud...
20:02:19 Set Baudrate to 921600
20:02:19 Reading,Wait...
20:02:20 Info:
20:02:20 Q7_TJGJ_L4_VIB_TG_PCB01_GPRS_MT6253_S00.Q7_TJGJ_L4 _VIB_XTG_X5_0719_V3_08.BIN_FLNTY5701111183KC
20:02:20 Device security area#1 is Ok
20:02:20 Keep Waiting...
20:05:42 Done.
20:06:13 File saved:C:\Documents and Settings\MdK\Bureau\gfive w5 mtk6252\Q7_TJGJ_L4_VIB_TG_PCB01_GPRS_MT6253_S00.Q7 _TJGJ_L4_VIB_XTG_X5_0719_V3_08.BIN_FLNTY5701111183 KC
20:06:35 Info:
20:06:35 Q7_TJGJ_L4_VIB_TG_PCB01_GPRS_MT6253_S00.Q7_TJGJ_L4 _VIB_XTG_X5_0719_V3_08.BIN_FLNTY5701111183KC
20:06:35 Device security area#1 is Ok
20:06:35 Keep Waiting...
20:06:35 >>
20:07:22 Pinout Applied
20:07:22 Press and HOLD Power button now
20:07:28 CPU£؛MT6253 Ver: 8A04 SW:8A00
20:07:30 Read Information From the Phone...
20:07:31 Unlock code 1111
20:07:31 Done.
Old 12-31-2012, 14:41   #50 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
Smile Mstar Model MACRONIX_MX25U6435E/F
14:31:30 Chip Scaning,Press and HOLD Power button now !
14:31:30 <<
14:31:37 Pin: 11 set as charge pin
14:31:39 <<
14:31:39 CPU: Mstar MSW853X
14:31:39 pinouts: D+:5 D-:6 Gnd:4
14:31:39 Checking port...
14:31:39 <<..
14:32:24 port:None
14:32:26 Pinout Applied
14:32:28 Pinout Applied
14:32:28 Phone detected, Wait...
14:32:32 Done.
14:32:32 Initialize boot6...
14:32:35 Boot Done.
14:32:35 Flash Type NOR
14:32:35 Flash ID 00C22537
14:32:35 Flash Model MACRONIX_MX25U6435E/F
14:32:35 Flash Size 0x800000(8,0M)
14:32:35 Reading,Wait...
14:32:55 Read Done.
14:33:05 File saved:C:\Documents and Settings\MdK\Bureau\Mstar_MACRONIX_MX25U6435E_F.bin
14:33:09 Pinout Applied
14:33:09 Phone detected, Wait...
14:33:12 Done.
14:33:12 Initialize boot6...
14:33:15 Boot Done.
14:33:15 Flash Type NOR
14:33:15 Flash ID 00C22537
14:33:15 Flash Model MACRONIX_MX25U6435E/F
14:33:15 Flash Size 0x800000(8,0M)
14:33:15 Starting,Wait...
14:33:21 Unlock code 0000
14:33:21 Unlock code 1122
14:33:21 Unlock code 2212
14:33:21 Done.
14:33:45 Search password,Wait..
14:33:46 Unlock code 0000
14:33:46 Unlock code 1122
14:33:46 Unlock code 2212
Old 01-04-2013, 10:25   #51 (permalink)
Member: 1400288
Thanks Meter: 21
MT6573 hang on logo DONE
11:22:55 Welcome to use McnPro light Box
11:22:55 Baud setting ...
11:22:57 Set Baud done
11:22:57 SW V12.25
11:22:57 FW 3.09
11:22:57 SN MCNL020418M0530D
11:22:57 AC 3314-6406-8223-5696-4371
11:22:57 Box Connected!
11:23:30 Searching USB to Serial Port...
11:23:30 Port:COM72
11:23:30 Press and HOLD Power button now
11:23:30 Release power button now !
11:23:30 CPU: MT6573[CA01]
11:23:31 Initialize boot 8 ...
11:23:40 Nand Flash Type [MICRON] MT29F4G08BAB
11:23:40 Nand Flash ID 002C00BC(00900055)
11:23:40 Nand Flash Size 21000000
11:23:40 File Mode
11:23:40 Reading size: 0x21000000
11:23:40 Reading,Wait...
11:48:11 Done.
11:48:11 File saved:C:\Program Files\Mcnbox Team\Mcnlight Box\MTK6573_13041123.bin
11:48:54 You can customize format address
11:48:54 Searching USB to Serial Port...
11:49:06 Port:COM72
11:49:06 Press and HOLD Power button now
11:49:07 Release power button now !
11:49:07 CPU: MT6573[CA01]
11:49:07 Initialize boot 8 ...
11:49:17 Nand Flash Type [MICRON] MT29F4G08BAB
11:49:17 Nand Flash ID 002C00BC(00900055)
11:49:17 Nand Flash Size 21000000
11:49:17 Formating...
11:49:20 Format Satrt Addr£º0x100000, Size: 0x300000
11:49:20 Done.
The Following User Says Thank You to haidar2 For This Useful Post:
Old 01-21-2013, 19:14   #52 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
Wink Iphone 4 6252 full support by mcnboxlight
15:59:51 Chip Scaning,Press and HOLD Power button now !
15:59:51 <<
15:59:54 PID&VID: 0E8D0003
15:59:54 pinouts: D+:4 D-:6 Gnd:15
15:59:56 Pinout Applied
15:59:57 Searching USB to Serial Port...
15:59:58 Port:COM77
15:59:58 Press and HOLD Power button now
15:59:59 Connected to Phone.
15:59:59 CPU: MT6250DA(625A) Ver: CA01 :0001]
16:00:03 Initialize boot 7 ...
16:00:07 Nor Flash ID 00C80060(00180000)
16:00:07 Nor Flash Size 1000000
16:00:07 Reading,Wait...
16:00:07 Info:
16:00:07 BENRUI50_12864_11B_PCB01_GPRS_MT6250_S00.BR_V02_55A.BIN
16:00:07 Device security area#1 is Ok
16:00:07 Keep Waiting...
16:00:52 Done.
16:01:00 File saved:C:\Documents and Settings\MdK\Bureau\CHINA\BENRUI50_12864_11B_PCB01_gprs_MT6250_S00.BR_V02_55A.bin
16:01:03 Searching USB to Serial Port...
16:01:21 User Abort
16:01:21 Searching USB to Serial Port...
16:01:21 User Abort
16:01:21 Reading NV...
16:01:23 Chip Scaning,Press and HOLD Power button now !
16:01:23 <<
16:01:27 PID&VID: 0E8D0003
16:01:27 pinouts: D+:4 D-:6 Gnd:15
16:01:28 Pinout Applied
16:01:29 Searching USB to Serial Port...
16:01:30 Port:COM77
16:01:30 Press and HOLD Power button now
16:01:31 Connected to Phone.
16:01:31 CPU: MT625A Ver: CA01  SW:0001
16:01:34 Read Information From the Phone...
16:01:49 Unlock code 0000
16:01:49 Done.
16:03:14 Chip Scaning,Press and HOLD Power button now !
16:03:14 <<
16:03:18 PID&VID: 0E8D0003
16:03:18 pinouts: D+:4 D-:6 Gnd:15
16:03:19 Pinout Applied
16:03:20 You can customize format address
16:03:20 Searching USB to Serial Port...
16:03:21 Port:COM77
16:03:21 Press and HOLD Power button now
16:03:23 Connected to Phone.
16:03:23 CPU: MT6250DA(625A) Ver: CA01 :0001]
16:03:26 Initialize boot 7 ...
16:03:30 Nor Flash ID 00C80060(00180000)
16:03:30 Nor Flash Size 1000000
16:03:31 Formating...
16:03:31 Format Satrt Addr£؛0xE60000, Size: 0x1A0000
16:03:32 Done.
16:10:43 PID&VID: 0E8D0003
16:10:43 pinouts: D+:4 D-:6 Gnd:15
16:10:44 Pinout Applied
16:10:45 MTK SF File: MT625A
16:10:45 Searching USB to Serial Port...
16:10:49 Port:COM77
16:10:49 Press and HOLD Power button now
16:10:50 Connected to Phone.
16:10:50 CPU: MT6250DA(625A) Ver: CA01 :0001]
16:10:54 Initialize boot 7 ...
16:10:58 Nor Flash ID 00C80060(00180000)
16:10:58 Nor Flash Size 1000000
16:10:58 Writing(Nand/SF)...
16:10:59 Erasing...142
16:11:50 Erasing...111
16:14:20 Done.
17:56:07 Chip Scaning,Press and HOLD Power button now !
17:56:07 <<
17:56:11 PID&VID: 0E8D0003
17:56:11 pinouts: D+:4 D-:6 Gnd:15
17:56:12 Pinout Applied
17:56:13 Searching USB to Serial Port...
17:56:15 Port:COM77
17:56:15 Press and HOLD Power button now
17:56:15 Connected to Phone.
17:56:15 CPU: MT625A Ver: CA01  SW:0001
17:56:20 Read Information From the Phone...
17:56:33 Write IMEI1 OK: 35561830225435-3
17:56:33 NONE IMEI2
17:56:33 NONE IMEI3
17:56:33 NONE IMEI4
Old 02-02-2013, 04:18   #53 (permalink)
Member: 1872415
hello seniors
i am newbie and mcnligt pro box user, however i am often succed to flash the phone. Please help me......maybe u can give me a right tutotial to using mcnlight pro.
many thanks and looking forward for u'r asistances
Old 04-27-2013, 18:17   #54 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
Successfully unlocked/repaired phones by Mcnpro light Box !
RESTART PROBLEM SOLVE BY MCNLIGHT BOX
MICROMAX X446 CPU MT625A READFLASH/FORMET/IMEI/ DONE
PHONE IMAGE
LOG HERE
FORMET
READ FLASH
IMEI
THANKS
MCNLIGHTBOX
Old 05-14-2013, 15:04   #55 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
Wink CPU: CoolSand
14:40:24 CoolSand Pinout Scaning,Press and HOLD Power button now !
14:40:24 <<#...
14:40:35 CPU: CoolSand
14:40:35 pinouts: Rx:7 Tx:6 Gnd:9 Vcc:1
14:40:37 Pinout Applied
14:40:37 Phone detected, Wait...
14:40:38 Done.
14:40:38 CPU Type Coolsand (88067000)
14:40:39 Flash Type NOR
14:40:39 Flash ID 00C80040(00160000)
14:40:39 Flash Model GD25Q32
14:40:39 Flash Size 0x400000(4,0M)
14:40:39 Reading,Wait...
14:56:07 Read Done.
14:59:03 File saved:C:\Documents and Settings\MdK\Bureau\CHINA\ZTC C700+---Coolsand_GD25Q32.bin
Old 06-21-2013, 00:03   #56 (permalink)
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
Thumbs up Successfully unlocked/repaired phones by Mcnpro light Box !
yxtel c900 formet / imei / read flash sucessfully done by mcnlight box no other box can do it but possible with mcn box thanks mcn team
procedure:- connect phone to pc by pressing boot key (volume -) with usb cable tick on usbcable in mcn software will auto dectect phone and done see in image shown do with this procedure 100% tested
note:- for any work with this cpu you have to do same procedure as above mention
phone image here
log here
read flash
formet
imei
flash file here
yxtel c900 flash file here download
THANKS MCNBOX TEAM
Old 07-28-2013, 23:55   #57 (permalink)
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
SEE THE POWER OF MCNLIGHT BOX 6820/8810 FORMET/WRITE FLASH/ FULLY SUPPORTED WITHOUT DEAD RISK
KARBONN A6 DEAD BY OTHER TOOL RECOVER BY MCNLIGHT BOX
phone was dead by other tool (karbonn A6) and i try with many tool and box but not sucess at last i try with mcnlight box and got sucess recover by mcnlight box
SEE LOG
WRITE FLASH HERE
FORMET
THANKS TO MCNBOX TEAM FOR GIVE US VERY USEFULL TOOL I WANT TO SAY ALL GSM FORUM USER IF STILL YOU DONT HAVE THIS TOOL THEN BUY IT TODAY IF YOU WANT MAKE MONEY ..!!
read flash 6820/8810 is under test will soon release after complete more hot news will continue stay tune ..
Old 08-01-2013, 19:23   #58 (permalink)
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
SPD 6530A CPU READFLASH /WRITEFLASH SUCESSFULLY WITH MCNLIGHT BOX
PHONE IMAGE HERE
READFLASH
WRITE FLASH
WRITE FLASH
FLASHFILE HERE
MAXX MSD7 6530A CPU_ NEW MODEL _OK_FILE.bin_links
Old 08-01-2013, 20:17   #59 (permalink)
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
NEW ver 1.3.0.5 fully supported read/write/formet for 6820/8810 cpu
see test report new ver 1.3.0.5
READ FLASH FROM KARBONN A1+PHONE
READFLASH LOG
WRITEFLASH & FORMET LOG HERE FROM
KARBONN A6
WRITE FLASH
FORMET
Old 03-08-2014, 13:13   #60 (permalink)
MDK23's Avatar
Member: 467636
Thanks Meter: 2,654
Smile I9300 cpu 6252 repair emei bu usb cable
I9300 CPU 6252 REPAIR EMEI BU USB CABLE
13:05:57 Set MediaTek USB Port (COM16)
13:05:57 Please Hold "ON" to connect with the phone...
13:05:59 Connected to Phone.
13:05:59 CPU: MT6250DA(625A) Ver: CA01 SW:0001
13:06:01 Read Information From the Phone...
13:06:14 W IMEI1 OK: 35444105569439-0
13:06:14 W IMEI2 OK: 35444205569440-8
13:06:14 NONE IMEI3
13:06:15 NONE IMEI4
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.34915 seconds with 10 queries
