Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported IMEI calculator Sites or Software Products > PB Tool for Smartphones
PB Tool for Smartphones Dongle Protected Solution for Smart Phones
Old 06-16-2012, 18:49   #1 (permalink)
GSM Solutions Ireland's Avatar
Member: 16771
Thanks Meter: 153
Pb tool problem[SOLVED]
I've tried installing on 32bit windows xp, each time i try start program it goes to splash screen and thats it.
I have tried all the standard ways to solve this issue, reinstall, .exe, drivers, different ports, etc.. etc.. nothing so far has worked.
Any ideas pb support?
Regards
Alan
Old 06-16-2012, 19:04   #2 (permalink)
Member: 1519258
Thanks Meter: 232
try this clue - uninstall egate driver
http://www.youtube.com/watch?v=6vfHpajQyyQ
The Following User Says Thank You to basia For This Useful Post:
Old 06-17-2012, 12:03   #3 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 729
brother this is just egate driver problem many tools is already install in ur pc therefore
see
the pic
Old 06-17-2012, 12:05   #4 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 729
and brother when any problem in using PBTOOL then post here
All users who have some Problem in PBTOOL using
Old 06-17-2012, 15:35   #5 (permalink)
pbtool's Avatar
Member: 1768459
Sonork: 1613455
Thanks Meter: 264
Problem solved or not ?
Br,
Old 06-17-2012, 16:52   #6 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 729
Regards
Alan
yess brother update us about ur problem
Old 06-22-2012, 18:18   #7 (permalink)
Member: 16771
Thanks Meter: 153
No, Problem not solved. This was a brand new machine with fresh install or XP. So no conflict with other drivers, software. I have also tested on another machine with Xp and still the same. Over 5 hours between 2 people and still no success.
Any ideas?
Old 06-23-2012, 03:14   #8 (permalink)
Member: 1519258
Thanks Meter: 232
then, need to change for reader please
or u can use Win 7 is 100% ok
Post the result
Old 06-23-2012, 05:11   #9 (permalink)
diosa's Avatar
Member: 1576733
Thanks Meter: 357
Any ideas?
Just install Service Pack 3, your problem will be solved.
The Following 2 Users Say Thank You to diosa For This Useful Post:
Old 06-23-2012, 09:36   #10 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 729
acutaly PBTOOL is new item in market therfore user facing some problem but its not mean that its not usble..
any one who have some problem in PBTOOL then post .
Old 06-23-2012, 09:36   #11 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 729
Old 06-23-2012, 11:16   #12 (permalink)
anttech's Avatar
Member: 1768456
Sonork: 1613455
Thanks Meter: 1,542
Any ideas?
Please Come to my sonork id
Let me check on TV!
Best Regard!
anttech
Old 06-25-2012, 15:22   #13 (permalink)
mr.omphonx's Avatar
Member: 714648
Sonork: 1609640
Thanks Meter: 908
conflict with other driver(e-gate)
1st on device manager u can disable egate driver and run PBTOOL for first after run pbtool succes u can plug other tool with egate drivers and driver for egate automatic instal,u can run 2 program or many program working at same time together (maybe this hard solution)
2nd easy solution u must use original xp/os and update ur os automatic with sp3, drivers not problem and no crash
in win 7 no problem anything
br,
mr.omphonx
Old 06-29-2012, 15:57   #14 (permalink)
reyfer24's Avatar
Member: 1044690
Sonork: 100.1617308
Thanks Meter: 50
They should fix this flaw with these drivers, not everyone has the availability of PC to be changing much less remove drivers that limits us to use other dongles and boxes.
Old 06-29-2012, 18:08   #15 (permalink)
Member: 1519258
Thanks Meter: 232
you make double post
PB Tool has this error
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 18:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.58705 seconds with 9 queries
