12-03-2013, 19:30 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | I have two phones plz confm me these phone supported on your server Samsung sm-N9005 Network O2 Germany. IMEI.358588058757625 Samsung sm-N9005 Network SFR France. IMEI.358588058931173 Sent from my iPhone using Tapatalk |
12-04-2013, 10:49 | #5 (permalink) |
No Life Poster Join Date: Aug 2012
Member: 1804503 Status: Offline Thanks Meter: 83 | Hello, You can use this service: Samsung Europe Unlock Codes Permanent Official Factory Unlocking Guaranteed And please read this also: How To Check Which Lock Needs Unlocking On Your Samsung Phone Turn on your phone without a sim inserted Key in *#7465625# this will display which lock is active (An easier way to remember this is *#SIMLOCK#) Doing this will display a screen similar to the example below, ON means that particular lock is locked, off means it is not locked.: Network Lock [ON] Network Subset Lock [OFF] SP Lock [ON] CP Lock [OFF] If only the Network lock is displayed saying ON then you will only need to use the NCK code with the instructions below. If you see the Subset lock value as ON then you will need the SCK code and if you see the SP lock value as ON you will need the SPCK code. How to enter specific unlock codes Once you know which lock(s) is active, you can now enter the specific code for it. If your phone says the NET lock is ON then you need to do this without a sim inserted: #7465625*638*NCKCODE# or #SIMLOCK*NET*NCKCODE# If your phone says the SP lock is ON then you need to do this without a sim inserted: #7465625*77*SPCKCODE# or #SIMLOCK*SP*SPCKCODE# If your phone says the Subset lock is ON then you need to do this without a sim inserted: #7465625*782*SCKCODE# or #SIMLOCK*SUB*SCKCODE# Best regards. |
12-04-2013, 10:59 | #6 (permalink) |
Member: 598395 Status: Offline Thanks Meter: 664 | I have two phones plz confm me these phone supported on your server Samsung sm-N9005 Network O2 Germany. IMEI.358588058757925 Samsung sm-N9005 Network SFR France. IMEI.358588058931173 |
12-04-2013, 16:41 | #7 (permalink) |
