11-12-2013, 10:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: sabageria
Member: 207455 Status: Offline Thanks Meter: 35 | Solved but phone still locked [SOLVED] |
11-12-2013, 16:42 | #2 (permalink) |
No Life Poster Join Date: Aug 2012
Member: 1804503 Status: Offline Thanks Meter: 83 | Hello, You were supposed to check before submitting to clean service if the imei is clean or barred. Every customer knows this by now. In the description of the service is it clearly stated: Only CLEAN iPhone are supported using this service. Please make SURE that your iPhone IMEI is CLEAN and NOT BARRED. As we can NOT unlock barred phones using this permanent official factory unlock for UNITED KINGDOM O2. If you are not sure about your iPhone IMEI is clean or barred please use CHECKMEND this is a cheap instant service working 24/7 that will generate a complete report of your iPhone and will save your time and money. It is also a MUST HAVE report if plan to sell your iPhone. So you can show the potential buyers that your iPhone is clean. You can see a CLEAN iPhone report and a BARRED iPhone report as example. DO NOT SUBMIT your iPhone unlock permanent official factory unlock using UNITED KINGDOM O2 if your IMEI is barred because you will NOT GET A REFUND. Please use iPhone Unlock Guaranteed service if available. The supplier refuses to refund, because the description of the service is clear. Please next time, before submitting to clean service, check to see if the imei is clean or barred, to prevent this from happening again. Best regards. |
11-12-2013, 16:59 | #3 (permalink) |
Member: 207455 Status: Offline Thanks Meter: 35 | its a cheating service you operate here you so trick customers off their cash course you show many discrepancies here, I will get back to legally soonest |
11-14-2013, 07:32 | #6 (permalink) |
Member: 1804503 Status: Offline Thanks Meter: 83 | Hello, So these order id`s were for the same imei. The message you got was: please activate your phone with any uk sim card. It means that the phone is not activated, so you need to activate first, and then use unlocking service. After you finally figured out that it needs to be activated with any uk sim card, you activated, and submitted to clean service, without checking if the phone is clean or not. Do you need me to explain something else? |
11-16-2013, 10:15 | #7 (permalink) |
Member: 207455 Status: Offline Thanks Meter: 35 | My posts are being edited! Funny cheat, if you can't give quality service, stop reaping people off, I read good and ain't ignorant, Kamal and infinity did unlocked phones I posted and you reaped me out off, not to bother after my litigation process i'll move entirely Last edited by bowei; 11-16-2013 at 10:22. |
11-18-2013, 17:04 | #8 (permalink) |
Member: 1804503 Status: Offline Thanks Meter: 83 | Sir, no one edits your posts. Last edited by bowei; 11-16-13 at 09:22. And if you would read the descriptions of the services before submitting, these kind of situations could be avoided. Best regards. |
11-20-2013, 08:15 | #10 (permalink) |
Member: 1804503 Status: Offline Thanks Meter: 83 | Hello, Unfortunately this phone model is not supported. So do not submit, because refund is not available if the phone model is not in the supported models list. Best regards |
