09-24-2012, 02:49
#1 (permalink)
Member: 1229604
Sonork: 100.1602688 Thanks Meter: 4,813 | cherry mobile c2 hang up solved see inside cherry mobile c2 hang up solved see inside
first ditect via piranhabox
logs here Quote:
Scaning MTK Pinouts,Connect the phone and Power On it
Nothing Pinouts Scanned out
Rx:7 Tx: 9
Gnd:2
CPU: MTK Model:6252
Pinout Setting Ok.
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6252A Ver: CA05 SW:0101
Loading Bootloader 7
Boot ERR: CC80_0
Pinout Setting Ok.
Abort by User
Pinout Setting Ok.
Abort by User
Connection Error,Please Check Cable bad. Sensing Failed
| verry hard to ditect
open fone
remove metal cover
then rehot MTK
then ditect again
logs here Quote:
Rx:7 Tx: 9
Gnd:2 Vcc:3
CPU: MTK Model:6252
Pinout Setting Ok.
Connected to Phone.
Nor Flash Code: 00C20025(00350000)
Nor Flash Size: 0x200000 Hex Bytes
INT/EXT RAM Size: 0x0+0x4C000000
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
The phone information:
A_TEAM_PCB01_GSM_MT6252_S01.M10AW1116.BIN
the file not be encrypted
Done.
| good ditection readinfo
format
logs here Quote:
Rx:7 Tx: 9
Gnd:2
CPU: MTK Model:6252
Pinout Setting Ok.
you can Set Formatting Addr
Connected to Phone.
Formatting Nor Flash...
Format Satrt Addr£º0x1DD000, Size: 0x23000
Formatted OK.
| write imei Quote:
Pinout Setting Ok.
CPU: MT6252 Ver: CA05 SW:0101
Read Information From the Phone...
W IMEI1 OK: 35432800651236-9
W IMEI2 OK: 35432800651237-7
NONE IMEI3
NONE IMEI4
| done
thanks
br: ernie78
piranhabox team |
