03-11-2013, 11:36 | #1 (permalink) |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,578 | coolsand formate after emergency (answered) set problem--auto off after 4-5 minutes read backup--ok format---ok repair imei--ok(check different and same) check after---set only show emergency format ago---network ok after rewrite --backup---network ok but same condition(auto off 5-6 minutes) any soluation |
03-11-2013, 14:35 | #5 (permalink) | |||
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Quote:
solution for that phone need to flash search same phone and same chip working then readflash then flash that phone for fast solved your problem Quote:
bro for searching network for coolsand chip this tip for you: how to fast solved firts step: tester the phone check if good open piranhabox software readinfo readflash format write imei tested if same search same phone firmware or search working phone then readflash then flash to your phone damage after flash not solved same problem check phone board check p.a and coolsand chip that step by step solution hope you understand my said | |||
