Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Piranha Box
Old 12-05-2012, 10:49   #1 (permalink)
Member: 1833881
MTK 6577 preloader restore
After a flash with a wrong firmware can not boot the MTK6577 phone.
For PC lets you fail to connect.
With the Piranha box can read the pinout but not establish USB connection.
"USB Error"
The same problem I have At another MTK6577 Phone.
Supports this box no MTK6577 CPU?
Old 12-05-2012, 10:55   #2 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688 Piranhabox
use usb mode
press bootkey insert usb
double check your phone driver
post result
Old 12-05-2012, 11:42   #3 (permalink)
Member: 1833881
phone driver is ok,
this work with my MTK6575 Phone.
this work not with my MTK6577 phone.
Old 12-06-2012, 04:46   #4 (permalink)
amar85's Avatar
Member: 1339214
Originally Posted by dorschdns View Post
phone driver is ok,
give me info about phone exact model
or please post logs or any erro w/your piranha box
Old 12-06-2012, 13:17   #5 (permalink)
Member: 1833881
hello,
this Phone is a MTK6577 Galaxy S3 Clone MHB9300 from EFOX Shop.
This is definitiv a MTK6577 in this Window from Piranha i see it MT6575
The same Problem is with all the other MTK6577 Phone they are testet from me.
Old 12-06-2012, 15:42   #6 (permalink)
Member: 1833881
hello,
This Phone from EFOX Shop is a BLUEBO 9300 (L100 OEM)
Old 12-07-2012, 01:58   #7 (permalink)
ernie78™'s Avatar
Member: 1229604
what is fone problem?? first u receive??
iff not detect please check hardware
br
Old 12-07-2012, 08:25   #8 (permalink)
Member: 1833881
This Box did not work with MTK6575 / MTK6577 "software - bricked Phones".
The bricked China Phones are unbricked without this Box. This Box did not work!
The Phone Hardware is 100% ok.
I have flashed a new Software at two Phones but one Phone will not work.
Old 12-28-2012, 11:29   #9 (permalink)
Member: 1833881
The Box is updated to the new FW and the PC SW Version is 1.15.
the box detects a 6577 Phone continue as 6575.
MTK6575????
other boot????
circuit bad??????
The Box did not work with all MTK Chip!
Old 12-29-2012, 03:33   #10 (permalink)
Member: 1285433
Sonork: 100.1621533
MTK6575????
other boot????
circuit bad??????
what is fone status now???
iff dead first check hardware
Old 12-29-2012, 10:21   #11 (permalink)
Member: 1833881
The Phone Harware is ok!
This Box will not work with wrong flashed MTK 6575 Phone and MTK6577 Phone.
Whe i connect with a worked Phone (6575 or 6577) the Box show the same Picture.
-CPU MT6575 ... the Phone is a MT6577 Phone.
-choice other Boot
-Circuit bad
Wrong flashed Phone MT6575 and MT6575 cant connect with this Box!
Old 12-29-2012, 10:21   #12 (permalink)
Member: 1833881
-choice other Boot
-Circuit bad
Old 12-30-2012, 00:00   #13 (permalink)
ernie78™'s Avatar
Member: 1229604
-choice other Boot
-Circuit bad
what is fone problem???
br: ernie78
Old 12-30-2012, 08:11   #14 (permalink)
Member: 1833881
br: ernie78
The (two) Phones are bricked with a wrong firmwareflash.
-wrong preloader
-the two Phones cant conect to PC
-the two Phones cant conect to the Piranha Box (no pinout)
Old 01-01-2013, 19:31   #15 (permalink)
Member: 1833881
Thank you...... ??????
How and what should I flash the new firmware to the phone if it can not connect to the PC and thus not with the SPFlashTool.
No Preeloader is detected.
I thought that these Piranha box can help me to repair a broken flashed phone again. That will not likely.
MTK 6577 Phones are recognized as MTK6575.
Did you personally tested this box with a defective phone MTK6577?
Did you repair this software broken Phone?
With what?
Which driver do you use?
Which PC system?
What unions do you use?
Please do not ever answer this "faulty hardware installed .... driver? ......"
Page generated in 0.40814 seconds with 10 queries
