09-06-2012, 07:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: I.N.D.I.A
Member: 256247 Status: Offline Thanks Meter: 444 | succusfull with pirahna box .#.... Rx:3 Tx: 4 Gnd:5 CPU: MTK Model:6225 Pinout Setting Ok. Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6225 Ver: 8A03 SW:8A00 CPU ID: 039F0000 Loading Bootloader 4 Nor Flash Code: 00EC257E(25082501) Nor Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0xC000+0x400000 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... The phone information: T7_DE66_PCB01_GPRS_MT6225_S00.T7_LOWCOST_V1_00.BIN the phone must be encrypted Abort by User Pinout Setting Ok. you can Set Formatting Addr Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6225 Ver: 8A03 SW:8A00 CPU ID: 039F0000 Loading Bootloader 4 Nor Flash Code: 00EC257E(25082501) Nor Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0xC000+0x400000 Formatting Nor Flash... Format Satrt Addr£º0xE00000, Size: 0x200000 Formatted OK. Pinout Setting Ok. Please Turn on your phone Connectted IMEI to be changed... OK, SN2: 91xxxxx0475757-9 |
09-06-2012, 08:01 | #2 (permalink) |
Member: 256247 Status: Offline Thanks Meter: 444 | Scaning MTK Pinouts,Connect the phone and Power On it .#.. Rx:7 Tx: 1 CPU: MTK Model:6235 Pinout Setting Ok. Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6235 Ver: 8A04 SW:8A01 Loading Bootloader 6 Abort by User Pinout Setting Ok. you can Set Formatting Addr Please Hold "ON" to connect with the phone... Scaning MTK Pinouts,Connect the phone and Power On it .#.. Rx:7 Tx: 1 CPU: MTK Model:6235 Pinout Setting Ok. you can Set Formatting Addr Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6235 Ver: 8A04 SW:8A01 Loading Bootloader 6 Nand Flash Type: [HYNIX] HY27xS08121M/A Nand Flash Code: 00AD0076(00AD0076) Nand Flash Size: 0x4200000 Hex Bytes INT/EXT RAM Size: 0x10000+0x0 Formatting Nand Flash... Format Satrt Addr£º0x2000000, Size: 0x2000000 Format nand OK Scaning MTK Pinouts,Connect the phone and Power On it .#.. Rx:7 Tx: 1 CPU: MTK Model:6235 Pinout Setting Ok. Please Turn on your phone please turn off the phone, and hit the little window Pinout Setting Ok. Please Hold "ON" to connect with the phone... CPU: MT6235 Ver: 8A04 SW:8A01 Read Information From the Phone... W IMEI1 OK: 91xxxxx273459-6 W IMEI2 OK: 91xxxxxx273000-8 NONE IMEI3 NONE IMEI4 |
09-06-2012, 08:01 | #3 (permalink) |
Member: 256247 Status: Offline Thanks Meter: 444 | Scaning MTK Pinouts,Connect the phone and Power On it .#... D+:3 D-:2 Gnd:5 PID&VID: 0E8D0003 Pinout Setting Ok. you can Set Formatting Addr Searching USB to Serial Port... MTK Serial Port: COM114 Please Hold "ON" to connect with the phone... Unstable usb port, maybe not set discharge pin Pinout Setting Ok. you can Set Formatting Addr Searching USB to Serial Port... Abort by User Searching USB to Serial Port... Abort by User Error usbport Pinout Setting Ok. you can Set Formatting Addr Searching USB to Serial Port... MTK Serial Port: COM114 Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6252A Ver: CB02 SW:0101 Loading Bootloader 7 Nor Flash Code: 00EF0040(00150000) Nor Flash Size: 0x200000 Hex Bytes INT/EXT RAM Size: 0x0+0x4C000000 Formatting Nor Flash... Format Satrt Addr£º0x1E4000, Size: 0x1C000 Formatted OK. Pinout Setting Ok. Searching USB to Serial Port... MTK Serial Port: COM114 Please Hold "ON" to connect with the phone... CPU: MT6252 Ver: CB02 SW:0101 Read Information From the Phone... W IMEI1 OK: 91xxxxxx273459-6 W IMEI2 OK: 91xxxxxx273000-8 NONE IMEI3 NONE IMEI4 |
09-07-2012, 12:04 | #4 (permalink) |
Member: 256247 Status: Offline Thanks Meter: 444 | micromax q7 formate and write imei with priahna box Scaning MTK Pinouts,Connect the phone and Power On it .#.. Rx:4 Tx: 3 CPU: MTK Model:6235 Pinout Setting Ok. you can Set Formatting Addr Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6235 Ver: 8A04 SW:8A01 Loading Bootloader 6 Nand Flash Type: [TOSHIBA] TC58NVG0S3AFT Nand Flash Code: 009800D1(00900015) Nand Flash Size: 0x8400000 Hex Bytes INT/EXT RAM Size: 0x10000+0x0 Formatting Nand Flash... Format Satrt Addr£º0x2000000, Size: 0x6000000 Abort by User Format nand OK Pinout Setting Ok. Please Hold "ON" to connect with the phone... CPU: MT6235 Ver: 8A04 SW:8A01 Read Information From the Phone... W IMEI1 OK: 35xxxxxx525222-2 W IMEI2 OK: 35xxxxxx562365-3 NONE IMEI3 NONE IMEI4 |
