Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Piranha Box
Old 12-24-2012, 06:34   #1 (permalink)
wohlstand's Avatar
Member: 1109337
Unstable usb port, maybe not set discharge pin
what causes this
MTK Serial Port: COM29
Please Hold "ON" to connect with the phone...
i always encounter this when using usb mode
Old 12-24-2012, 07:30   #2 (permalink)
amar85's Avatar
Member: 1339214
unstable usb port, maybe not set discharge pin
meaning
not supported this cpu for repair imie using usb cable
you can repair imie via rx tx or fbus cable
Old 12-25-2012, 05:40   #3 (permalink)
boy_muslim's Avatar
Member: 452214
Sonork: No warranty
Repeat operation
Unplug USB and BATT. then try again
post result dear
Old 12-29-2012, 16:55   #4 (permalink)
Member: 1833881
I have the same Problem with MT6573 Phone.
After "Unplug USB and BATT. then try again" the same Result in USB Mode.
Old 12-30-2012, 10:44   #5 (permalink)
boy_muslim's Avatar
Member: 452214
Sonork: No warranty
make sure driver is installed
some MTK phone needs bootkey by pressing it one by one
MENU
CALL Button (GREEN)
0 number
Old 12-30-2012, 10:44   #6 (permalink)
boy_muslim's Avatar
Member: 452214
Sonork: No warranty
MENU
CALL Button (GREEN)
0 number
Old 12-30-2012, 11:00   #7 (permalink)
Member: 1833881
MENU
CALL Button (GREEN)
0 number
the driver are installed, this Phone are a Smartphone
- menuButton?
-Call Button?
-0 Number?
they Buttons are not available!
Old 12-30-2012, 13:24   #8 (permalink)
amar85's Avatar
Member: 1339214
Originally Posted by dorschdns View Post
the driver are installed, this phone are a smartphone
- menubutton?
-call button?
-0 number?
They buttons are not available!
give me info about your phone model and problem
what is exact cpu type
sorry for late reply
Old 12-30-2012, 15:21   #9 (permalink)
Member: 1833881
The Phone Model is
-N9770 (CPU - MTK6577)
-X710D (CPU - MTK6577)
the Phones are flashed with a wrong Firmware.
the Phones cant connect with the Box or PC.
Old 12-30-2012, 23:11   #10 (permalink)
Member: 1285433
Sonork: 100.1621533
The Phone Model is
fone not connect because bootkey is wrong
what is fone flash id??
please post screenhot clear here
br/piranhabox-help
Old 12-31-2012, 09:19   #11 (permalink)
Member: 1833881
br/piranhabox-help
Where can I see this ID?
I've tried all the buttons, a BootKey can not be found.
Old 12-31-2012, 09:21   #12 (permalink)
Member: 1833881
br/piranhabox-help
The phone can not connect to the box.
Old 12-31-2012, 12:49   #13 (permalink)
Member: 1813001
The Phone Model is
bro use this thread
for Haipai X710D Haipai X710D MTk6577 Flash Problem sdcard/ext - xda-developers
for star N9770STAR N9770 DUAL CORE MT6577/ulefone N9770. - xda-developers
if above mentioned models are present in this link then ur 90% problem solved.....
if this link not help u, then beyond this no one help u........
BEST OF LUCK
The Following User Says Thank You to OK MOBILE For This Useful Post:
Old 01-01-2013, 19:30   #14 (permalink)
Member: 1833881
Originally Posted by OK MOBILE View Post
bro use this thread
BEST OF LUCK
Thank you...... ??????
How and what should I flash the new firmware to the phone if it can not connect to the PC and thus not with the SPFlashTool.
No Preeloader is detected.
I thought that these Piranha box can help me to repair a broken flashed phone again. That will not likely.
MTK 6577 Phones are recognized as MTK6575.
Did you personally tested this box with a defective phone MTK6577?
Did you repair this software broken Phone?
With what?
Which driver do you use?
Which PC system?
What unions do you use?
Please do not ever answer this "faulty hardware installed .... driver? ......"
Page generated in 1.90494 seconds with 10 queries
