All SPD & ALL MTK CPU USB NOT DETECTED SOLUTION STEP BY STEP BY MIRACLE TEAM All SPD & ALL MTK CPU USB NOT DETECTED SOLUTION STEP BY STEP BY MIRACLE TEAM SPD 6531 Bar Phone & SPD 8810 Android Phone Finding Of Boot Key For Spd First Of All Insert Batrry And Wait 5 to 10 Second And Then Press And Hold Check One By One All Keys And Press Power Key If Set Is Going To On Then It Is Not Boot Key If Set Is Not On Till 5 Seconds Then This Is Boot Key & Manual Pinouts Slect For Spd 6531 Check This Gif Video All SPD & ALL MTK CPU BAR & ANROID PHONE If Usb Jack Is Damaged Or Not Detected Then Cut Usb Cable And Sold It Wires On Board explain Here With New User Usb Jack Is Damaged If Pc Show Usb Not Recognised Then Change , Dp-, Dm+ Wire With Eachother |
Keep it yup brother your salution 100% working |
Helpful solution thanks zulfqarali (JAMIMOBILE) Helpful solution thanks zulfqarali (JAMIMOBILE) Mehtab Mobiles Thari Mirwah 03003726456 |
This is really good solution |
pls give some SPD 6531 Bar Phone boot key |
how to DETECTED ded condition SPD 6531 Bar Phone ,phone pinouts (formet ded) |
Bor cell Boot Is Not Dead First Of All Insert Batrry And Wait 5 to 10 Second And Then Press And Hold Check One By One All Keys & Write Backup Or Working Phone File Br, Miracle Team |
If You Cant Find Boot Key Just Open Your Set Solder Rx Tx Gnd By Rj45 Cable Than Go To Pin Out Tab If You Cant Success Post Result .: BR :. ..:: [ S V ] ::.. ..::: MIRACLE TEAM :::.. http://s13.postimg.org/ep3htf21j/05b5.gif Br:) Palash Ahammad |
Boot Keys 1. Power button 2. Home/Menu key 3. Call key, 4. Camera button (when camera button on phone) 5. 5 key 6. * key 7. # key 8. 0+2 9. 0+2 10. *+# 11.In Touch Phone Mostly Volum Down Key BR, MIRACLE TEAM |
brother same spd are not in DETECTED Rx Tx................................................ .............................. |
thanks for all, my problem solved............................................ .......................... |
PLEASE HELP ME WITH THIS PLEASE IS NOT DETECTING ANY SPD PHONE I HAVE INSTALLED ALL SPD DRIVERS SAME PROBLEM I HAVE UPDATED AND ALSO CHECKED HERE C:\Program Files\Miracle Box\BOX_Data\Drivers\Mobile Driver....BUT IS EMPTY ONLY NOTPAD AND MIRACLE PIC FOUND PLEASE HELP ME I HAVE DONE ALL I KNOW SAME PROBLEM http://imageshack.com/a/img923/6192/b0Q6kE.jpg |
x424 plus boot key plz tried but not working |
