Old 05-23-2015, 12:53   #1 (permalink)
Member: 1273573
Sonork: 100.1623251 QQ.2905713135
Thanks Meter: 3,780
All SPD & ALL MTK CPU USB NOT DETECTED SOLUTION STEP BY STEP BY MIRACLE TEAM
BY
MIRACLE TEAM
SPD 6531 Bar Phone & SPD 8810 Android Phone
Finding Of Boot Key For Spd
First Of All Insert Batrry And Wait 5 to 10 Second
And Then
Press And Hold Check One By One All Keys And Press Power Key
If Set Is Going To On Then It Is Not Boot Key
If Set Is Not On Till 5 Seconds Then This Is Boot Key
Manual Pinouts Slect For Spd 6531
Check This Gif Video
BAR & ANROID PHONE
If Usb Jack Is Damaged Or Not Detected Then
Cut Usb Cable And Sold It Wires On Board
explain Here With New User Usb Jack Is Damaged
If Pc Show Usb Not Recognised Then Change , Dp-, Dm+ Wire With Eachother
Br,
The Following 30 Users Say Thank You to zulfqarali For This Useful Post:
Old 05-23-2015, 16:31   #2 (permalink)
Member: 1905774
Sonork: 100.1646709
Thanks Meter: 972
Keep it yup brother your salution 100% working
The Following User Says Thank You to shaikh.mushahid For This Useful Post:
Old 05-24-2015, 09:30   #3 (permalink)
Member: 2263794
Helpful solution thanks zulfqarali (JAMIMOBILE)
Mehtab Mobiles
Thari Mirwah
03003726456
The Following User Says Thank You to mehtab.mobiles For This Useful Post:
Old 05-24-2015, 19:42   #4 (permalink)
Member: 2382987
Sonork: 100.1593127
This is really good solution
Old 05-25-2015, 06:50   #5 (permalink)
Member: 562003
Thanks Meter: 42
Old 05-27-2015, 19:16   #6 (permalink)
khalidahmed's Avatar
Member: 2298142
Thanks Meter: 240
pls give some SPD 6531 Bar Phone boot key
Old 05-27-2015, 19:27   #7 (permalink)
Member: 2298142
Thanks Meter: 240
how to DETECTED ded condition SPD 6531 Bar Phone ,phone pinouts (formet ded)
Old 05-28-2015, 05:33   #8 (permalink)
Member: 1273573
Thanks Meter: 3,780
Bor cell Boot Is Not Dead
And Then
& Write Backup Or Working Phone File
Br,
Old 05-28-2015, 06:16   #9 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
If You Cant Find Boot Key Just Open Your Set Solder Rx Tx Gnd By Rj45 Cable
Than Go To Pin Out Tab If You Cant Success
Post Result
.: BR :.
..:: [ S V ] ::..
..::: MIRACLE TEAM :::..
Palash Ahammad
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 05-28-2015, 08:13   #10 (permalink)
rameshwarpooja's Avatar
Member: 1311498
Sonork: 100.1662995
Thanks Meter: 513
Some SPD Phones Need to Press Boot Key For Detect By Box
Boot Keys
1. Power button
2. Home/Menu key
3. Call key,
4. Camera button (when camera button on phone)
5. 5 key
6. * key
7. # key
8. 0+2
9. 0+2
10. *+#
11.In Touch Phone Mostly Volum Down Key
BR,
MIRACLE TEAM
Old 05-29-2015, 07:53   #11 (permalink)
Member: 2298142
Thanks Meter: 240
brother same spd are not in DETECTED Rx Tx................................................ ..............................
Old 05-29-2015, 07:55   #12 (permalink)
Member: 2298142
Thanks Meter: 240
thanks for all, my problem solved............................................ ..........................
Old 05-17-2017, 12:51   #13 (permalink)
Member: 1817604
Thanks Meter: 6
PLEASE HELP ME WITH THIS PLEASE IS NOT DETECTING ANY SPD PHONE I HAVE INSTALLED ALL SPD DRIVERS SAME PROBLEM I HAVE UPDATED AND ALSO CHECKED HERE C:\Program Files\Miracle Box\BOX_Data\Drivers\Mobile Driver....BUT IS EMPTY ONLY NOTPAD AND MIRACLE PIC FOUND PLEASE HELP ME I HAVE DONE ALL I KNOW SAME PROBLEM
http://imageshack.com/a/img923/6192/b0Q6kE.jpg
Old 07-02-2019, 03:55   #14 (permalink)
Member: 2878734
Thanks Meter: 2
x424 plus boot key plz tried but not working
Old 07-02-2019, 14:17   #15 (permalink)
Member: 2878734
Thanks Meter: 2
The Following User Says Thank You to sultan_gsm For This Useful Post:
Page generated in 0.30796 seconds with 8 queries
