11-06-2012, 13:30 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | ★★★★★ All Successful Repair Stories By Miracle Eagle Eye ★★★★★ Last edited by [SV]; 10-03-2015 at 13:18. Reason: Image Modification |
The Following 7 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-13-2012, 06:55 | #2 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | agild x5 dead recovered by formate gild x5 dead recovered by formate only in MIRACLE-EAGLE EYE restore og imei WBR- TEAM MIRACLE DEEPESH SHARMA Last edited by Deepesh Sharma; 06-18-2013 at 05:57. |
11-13-2012, 07:10 | #3 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | lg kp 100 inf cpu read code LG KP 100 READ CODE 1ST NEED TO READ FULL FLASH FILE THEN FILE UNLOCK READ FLASH FILE FILE UNLOCK WBR-TEAM MIRACLE |
The Following 8 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-14-2012, 06:57 | #4 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | gild v2 read file and reapir no services via write nv file Gild v2 read flash file and repair no services write nv file sucessfull with MIRACLE-EAGLE EYE READ FLASH FILE WRITE NV FILE BR- TEAM MIRACLE |
The Following 13 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-14-2012, 12:31 | #5 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Gfive c3620 fix white disply with flash hi to all here new solution for white disply TODAY GET WHITE DISPLY SET GFIVE C3620 IN HAND SET CALL INCOMING/OUT GOING OK I TRIED TO CHANGE MANY LCD THEN I FLASHED SET AND NO NEED TO CHANGE LCD IT'S REALY MIRACLE GFIVE C3620 FLASHED BR-TEAM MIRACLE |
The Following 12 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-14-2012, 12:46 | #6 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Onida g465 read flash file ONIDA G465 READ FLASH FILE BR-TEAM MIRACLE |
11-15-2012, 07:11 | #7 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | micromax x266 read flash file and auto remove password MICRO MAX X266 READ FILE AND AUTO REMOVE PASSWORD NO NEED TO 1ST READ PASSWORD THEN INPUT IN PHONE JUST ONE CLICK IN AUTO UNLOCK AND ENJOY NOTE- NO ANY DATA WILL LOST ONLY REMOVE PASSWORD READ FLASH FILE AUTO REMOVE PASSWORD BR-TEAM MIRACLE DEEPESH SHARMA Last edited by [SV]; 11-15-2012 at 10:01. |
11-16-2012, 09:15 | #8 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Micromax x233(mstar cpu) read flash/read code on usb mode MICROMAX X233 READ FLASH AND READ CODE ON USB MODE IN MIRACLE EAGLE-EYE READ FLASH FILE READ CODE BOOT KEY- PRESS AND HOLD CALL KEY(GREEN KEY) then insert usb cable no need bettry WBR- TEAM MIRACLE |
11-17-2012, 05:32 | #9 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | geotel champion read flash file geotel champion read flash file |
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-17-2012, 10:57 | #10 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Carlvo a41 read code CARLVO A41 READ CODE DONE BY MIRACLE-EAGLE EYE |
11-18-2012, 12:21 | #11 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | spice m4580n read flash file SPICE M4580N READ FLASH FILE |
11-19-2012, 06:59 | #12 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | spice M-5454 read unlock code spice m5454 read unlock code |
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-20-2012, 09:31 | #13 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Wing m18 read file and read code WING M18 READ FILE AND READ CODE ON EAGLE-EYE READ FILE READ CODE |
11-22-2012, 06:39 | #14 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Gfive F8 Dead Recovered BY Flash Gfive F8 Dead Recover By Flash In MIRACLE-EAGLE EYE |
The Following 6 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-24-2012, 13:44 | #15 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | yxtel c6 read code and flash file in usb mode YXTEL C6 READ CODE AND FLASH FILE IN USB MODE IN MIRACLE EAGLE-EYE READ CODE READ FILE BR- TEAM MIRACLE |
