Old 10-03-2018, 14:00   #1 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 336
>>> Redmi Note 4X MIDO Mi account remove? <<<
Hi, mates.
Xaomi Redmi Note 4X MIDO after "MI Prevent Relock" just hangs on logo!
How to solve this problem, mates?
How to remove MI Account for good.
By the way, when I remove the account with "MI Account unlock" the account is removed, but when I connect the phone to WIFI it ask me again for account. That's why I try with "MI Prevent Relock" but the phone hangs on logo every time and I have t revive it with flash.
Old 10-04-2018, 18:48   #2 (permalink)
Registered User
Member: 1982255
Sonork: mnb_noor
Thanks Meter: 15
http://forum.gsmhosting.com/vbb/f753...-done-2463526/
Old 10-05-2018, 09:03   #3 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 336
Thank you, mate, for your response, but take a look again at my problem. The MI Account is removed, but after connecting to WIFI, the phone ask me again for MI Account. It's temporery! And when I try to prevent relocking through "MI Prevent Relock", the set hangs on logo and I have to flash it to revive it. I tried downgrading to EMUI 8 - again the same problem. Hangs on "MI" logo. So Im asking, what should I do to remove MI Account for good!
Old 10-05-2018, 10:40   #4 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 336
* MIUI 8, sorry for the hurry mistake
Old 10-11-2018, 09:15   #5 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 336
Just to ask, cause Im a new Miracle user, I bought Miracle just a couple of weeks ago, Is there a support team around here at all? Or we have to do everything by ourselfes, when something is not working properly with the box?! Is this box/section have a supporters at all?!
Thank you for your answer
Old 10-11-2018, 10:23   #6 (permalink)
Member: 2740295
Thanks Meter: 33
VOdafone Smart turbo 7 VFD 500 Unlock done By CM2 Just 32 Seconds
How To Unlock
1st Install CM2 InfinityBox_install_CM2MTK_v1.58
2nd Open InfinityBox CM2MTK Module
3rd Select Model from Setting Tab
4th Go to Security Tab and Click To SP UNLOCK
Done
Here is Log
Operation : SP Unlock [ v1.58 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9B
NAND Flash : NOT INSTALLED
eMMC Flash : 300001113747383055B700303BFDF79B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 07G80
[eMMC] : FLASH_CID : 11010030303847373000B7559BF7433B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x19CEE0A855AF876CDA53271A41A05039
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:32
Reconnect Power/Cable!
Old 10-11-2018, 11:00   #7 (permalink)
DundyTM's Avatar
Member: 889564
Thanks Meter: 336
Originally Posted by raju24.bd View Post
How To Unlock
Done
Here is Log
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:32
Mate, you're posting in the wrong section about wrong phone
Page generated in 0.81080 seconds with 8 queries
