11-18-2016, 16:59 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Micromax A104 MT6582 Unfortunately System Has Stopped Solved By Miracle Eagle Eye Micromax A104 MT6582 Unfortunately System Has Stopped Solved By Miracle Eagle Eye Box First Format Then Flash Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Definition Applied you can Set Formatting Addr Waiting for USB Port... Set PreLoader USB VCOM Port (COM10) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x00E6800000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x40000000 Formatting Nand Flash... Format Satrt Addr£º0x4D380000, Size: 0x38C00000 Verify...Done. Format nand OK(Android Need to wait a few minutes the phone is switched) System Info: id:MMX_A104_SW_V8.1.0_HW_V1.0_20140929 version:4.4.2 model:Micromax A104 brand:Micromax manufacturer:Micromax Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set PreLoader USB VCOM Port (COM10) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6582 SW:0001 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x00E6800000 Flash Type: EMMC INT/EXT RAM Size: 0x20000/0x40000000 Writing(Nand/eMMC)... Writing MBR Writing EBR1 Writing UBOOT Writing BOOTIMG Writing RECOVERY Writing SEC_RO Writing LOGO Writing EBR2 Writing ANDROID Writing CACHE Writing USRDATA Checking Sum... Write Done. >>Total time: 4 mins 15 s |
