Old 04-20-2018, 05:26   #1 (permalink)
Member: 918560
Thanks Meter: 4
eagleeye v2.71 error
after instel v2.71,error update not fileexists
Old 04-20-2018, 08:13   #2 (permalink)
Member: 2253192
Thanks Meter: 47
same error here
please help miracle team
Old 04-22-2018, 12:16   #3 (permalink)
Member: 2158420
Thanks Meter: 36
same problem, after instel v2.71,error update not fileexists
Old 04-22-2018, 12:50   #4 (permalink)
Crazy Poster
Member: 799224
Sonork: 09214055808
Thanks Meter: 7
plz .....plz.......plz.........need help agent...............same problem ...........Error ID: Update not fileexists
Old 04-23-2018, 10:48   #5 (permalink)
Member: 1119285
Error ID: Update not fileexists help me please
Old 04-25-2018, 03:37   #6 (permalink)
Member: 1515141
Same problem here but no solution where is the team experts
Sent from my Lenovo K8 Note using Tapatalk
Old 04-25-2018, 05:03   #7 (permalink)
Member: 326228
Thanks Meter: 31
Post miracle eagle eye 3.71 open port error
Welcome to use Miracle Box
(World's First Fuzzy Logic Based Tool)
Update:18-02-10
Firmware Version:1.15
Connected OK.
Fuzzy Logic Method is very safe and reliable !
License Expire Date: 2018-12-04
Error ID: Update not Fileexists
1. Phone switched Off
2. Press Vol+ or Vol-,Connect Mobile with USB Cable
Or use specialized USB Cable,Enter Edl(9008) mode
3. Scan Port
Definition Applied
Connecting to Phone,Wait..
Open port error, Port is occupied or non-existent
>>Please RePower on & off
why I am getting this error every time
after updating to 3.71 miracle eagle eye
Old 04-25-2018, 06:49   #8 (permalink)
Member: 326228
Thanks Meter: 31
hi every one I found a solution for miracle eagle eye v2.71 which was not working properly
first install miracle box setup 2.72 from here Setup_Miracle_Box_v272
now copy box_data from installed folder and save it to another folder
now remove miracle box setup 2.72
now extract miracle eagle eye setup to c drive and delete box_data from the extracted setup
now copy the folder that was copied from miracle box 2.72 and paste it tomiracle eagle eye folder
now run miracle eagle eye your box firmware will be upgraded to 1.16 and your problem will be solved
if your problem is solved pray for my better health as speedy recovery
thankyou
Page generated in 0.17181 seconds with 8 queries
