04-24-2018, 10:25 | #19 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Kishtwar/Islamaabad j&k Age: 45
Member: 326228 Status: Offline Thanks Meter: 31 | miracle eagle eye 3.71 open port error Welcome to use Miracle Box (World's First Fuzzy Logic Based Tool) Update:18-02-10 Firmware Version:1.15 Connected OK. Fuzzy Logic Method is very safe and reliable ! License Expire Date: 2018-12-04 Error ID: Update not Fileexists 1. Phone switched Off 2. Press Vol+ or Vol-,Connect Mobile with USB Cable Or use specialized USB Cable,Enter Edl(9008) mode 3. Scan Port Definition Applied Connecting to Phone,Wait.. Open port error, Port is occupied or non-existent >>Please RePower on & off why I am getting this error every time after updating to 3.71 miracle eagle eye |
04-25-2018, 05:06 | #21 (permalink) |
Member: 326228 Status: Offline Thanks Meter: 31 | miracle eagle eye 3.71 open port error -------------------------------------------------------------------------------- Welcome to use Miracle Box (World's First Fuzzy Logic Based Tool) Update:18-02-10 Firmware Version:1.15 Connected OK. Fuzzy Logic Method is very safe and reliable ! License Expire Date: 2018-12-04 Error ID: Update not Fileexists 1. Phone switched Off 2. Press Vol+ or Vol-,Connect Mobile with USB Cable Or use specialized USB Cable,Enter Edl(9008) mode 3. Scan Port Definition Applied Connecting to Phone,Wait.. Open port error, Port is occupied or non-existent >>Please RePower on & off why I am getting this error every time after updating to 3.71 miracle eagle eye |
04-25-2018, 06:47 | #22 (permalink) |
Member: 326228 Status: Offline Thanks Meter: 31 | solution 2.71 error hi every one I found a solution for miracle eagle eye v2.71 which was not working properly first install miracle box setup 2.72 from here Setup_Miracle_Box_v272 now copy box_data from installed folder and save it to another folder now remove miracle box setup 2.72 now extract miracle eagle eye setup to c drive and delete box_data from the extracted setup now copy the folder that was copied from miracle box 2.72 and paste it tomiracle eagle eye folder now run miracle eagle eye your box firmware will be upgraded to 1.16 and your problem will be solved if your problem is solved pray for my better health as speedy recovery thankyou |
